Morning all,
Had a problem with the windscreen wiper fluid since I got this car, there is obviously a block somewhere in the system as I can fill the container and see the level sit at full, but can't get any pressure for it to spray out. one side manages a few drops the other shoots maybe just 5cm. There isn't any leaks that I can see as I've filled it a few times over dry concrete and found no puddles so I assume the lines must be blocked?
Is this a common problem/anywhere common to start looking for the block?
Cheers,
Jimmy
pull the washer pump out and there is a rubber strainer type thing, that gets blocked up with slime, clean it out and it should be fine
Originally Posted by Adam Savage (mythbusters)
+1 for the slime on the screen
The Daily:6/93 VR Executive SedanVQ V8 Long Range Tank L3 Dash Conversion VR Calais Leather Seats VR II Steering Wheel VTSS Mags Aqaumarine in Colour![]()
The Weekender:6/07 BF XR8 6 Spd Manual Sedan Ego Paint Pedders Coilovers Adj.Swaybars Shelby GT500 Rotating Assembly 2800lb Twin Plate Yella Terra CAI FPV Gauge Pod Full Sports Leather Interior
Tuned by Glenmore Motors,Rockhampton-345RwHp,13.8ET with crappy tires and bulk wheel tramp
Disconnect the hoses from the washer jets then see if that works , sometimes the jets get blocked and you have to use a bit of wire to clean the crap out of the jets .
where abouts in the engine bay is the washer pump? my vs also has the windscreen washer issue. i have disconnected the hoses to the jets and tried firing them like that as dayvo suggested but that made no difference so i want to try cleaning out the washer pump as you suggested
ok thanks for that. ill suss it out tomorrow
