Results 1 to 11 of 11
Thread: What the hell is wrong with my car?!!
    Patti2912's Avatar
    Patti2912 is offline P4TT1
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Default What the hell is wrong with my car?!!
    My 93 VR has a duel fuel system installed.
    Never had a problem until about 2 weeks ago, it stopped running on petrol.
    Wouldn't start when the switch was on Petrol, though would on gas, and when switched back to petrol it would stall.
    Pretty sure there's a problem with the Solenoid, which doesn't bother me as i am booked in to get it looked at and fixed, though this afternoon whilst driving home (on gas), i heard a very loud 'pop' sound, which i can't be 100% sure but it sounded as though it was from under the bonnet,
    I then lost all power in the car, so i pulled over.
    The car then wouldn't start at all, but i (for some reason) hit the switch to change it to petrol, and it started with no problem, and i drove home on petrol.
    WHAT THE HELL IS WRONG WITH IT?!!
    Also (i don't know if this is related to the same problem), when i switched it back to petrol there was a 'sssshhhhhhhhhhhhh' kind of sound from under the bonnet when in drive, and would stop as i accelerated.
    Sounded to me as though it was one of the belts, but i can't be sure..
    Can anyone suggest what may be going on?
    **UPDATE**
    So i decided to update this in case anyone is having the same problem and wonders what it is.
    I had my car looked at today, turns out that the solenoid was fine, and that there was more than likely just a bad blockage in the fuel pump, and somehow when the car (on gas) backfired, it unblocked it, though the back fire blew the top off the gas mixer, which was replaced for $40.00.
    And the 'shhh' sound was simply just a shot bearing, so nothing major which i figured would be the case.
    Hope this helps anyone that may be experiencing the same confusing problems,
    And thanks for everyone that replied
    Quote Originally Posted by Morton View Post
    You're better off using a 175g can of Masterfoods Wholegrain Mustard. I just measured that, and it's 9.5cm tall. Keep one in your car at all times, and if a police officer tries the "coke can test", you can tell him what I told you
    VX II Calais LS1
    Jan 2010
    petrol problem: fuel pump is nearly dead
    gas problem: the back fire on gas has destroyed your airbox, making it run rough on gas.
    Thats my guess
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Quote Originally Posted by bandit10 View Post
    Thats my guess
    That's a good guess man.
    I originally thought the first problem (car not running on petrol) was something to do with the fuel pump, but as of today now that its somehow switched back to petrol its running perfectly, not missing a beat. I will get this looked at though, thanks.
    And in regards to the gas problem you stated, again it runs really well on gas. Would your guess have it run fine but back fire or make this 'pop' sound occasionally?
    VX II Calais LS1
    Jan 2010
    if your airbox is damaged from a backfire it will cause it to backfire again and run rough, depending on how much damage is done to the airbox.
    The pop sound is most likely a backfire.
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    with the air box you should do the taxi trick and oky strap it so when it backfires the ockys just strech and open the box good trick
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    So what i gather from this is that for whatever reason it may have backfired previously, and damaged the airbox, which will continuously make it worse and worse?
    Lucky i have it booked in to an LPG mechanic tomorrow then huh.
    vr berlina
    Aug 2010
    australia
    still do the oky strap trick cuz if you need to get a new air box you will want to protect the new one
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Quote Originally Posted by vr1uz-fe View Post
    So the idea is that you have the strap on it constantly?
    How and what exactly would i have to do to do it? I don't fully understand what your strapping and where.
    Sorry for being a bit naive to the matter.
    vr berlina
    Aug 2010
    australia
    there are five clips/clamps on the air box you can unclip them with your fingers to change the air filter but when they are cliped down they hold the box on tight so when gas gets down there and burns it can blow a hole in the box i have done it once at work now what you do is un clip them but then the box can just pop off as there is nothing holding it down so you get two oky straps from bunnings and strap them on so when the gas go's bang it just lifts the lid off the air box and lets the pressure out without breaking any thing
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Oh yeah cool, makes total sense now that you explain it.
    Thanks heaps for that man, i really appreciate it.
    Ill be doing that asap
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    When it makes the "shhhhhhh" sound does it feel like it won't pull? If so it's leaning out.
  1. Another Wrong colour fluid in wrong chamber?
    By just_vt_problems in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2010, 07:14 PM
  2. It's Hell Getting Old
    By Dayvo in forum Jokes/Humour
    Last Post: 11-06-2008, 11:25 AM
  3. What the hell is it, and why???
    By gupatrol in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2008, 06:15 PM
  4. what the hell
    By caminsa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2007, 04:32 PM
  5. Who The Hell
    By throttlehappy in forum The Pub
    Last Post: 07-12-2005, 09:31 PM
