Results 1 to 5 of 5
Thread: VS Commodore equipe boot seal problem
    danielj_au99 is offline Slick
    96 vs commodore equipe
    Jan 2010
    Perth, Australia
    Default VS Commodore equipe boot seal problem
    Hi all my VS Commodore equipe has been having a leak in the boot multiple times and it gets all the crap in the back wet has anyone had this problem? i have tried to find out where the water is coming through but have had no luck CHEERS fo your help
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Someone here did a thread on how to fix it. Pretty good detail. Search for it. Either this forum or the ''Other'' forum.
    It leaks through that funny trim thing on the rear pillar next to that little window thing. You have to take the glass out and fix it from the inside.
    I chose the easier way. Drilled little drain holes and left it at that lol.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    The "usual" vr/vs boot leak is from the rear quarter window. Most people pull it out (pull off the trim and you should see the screws), then use a bit of windscreen sealant or similar to seal it up
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Quote Originally Posted by Philthy View Post
    Yep, that's what I did and it's worked 100%. Right hand side usually but I did both sides.
    Jan 2010
    Perth, Australia
    Cheers guys
  1. VX Equipe II Aircon Problem...
    By Mitch_B in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-07-2010, 07:03 PM
  2. Vr commodore boot button problem.
    By sik_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2010, 09:27 PM
  3. VN Commodore Boot Problem
    By RockinRobins in forum General Discussion
    Last Post: 20-02-2010, 04:51 PM
  4. rubber seal at base of t5 gear shift (not the boot)
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-12-2008, 03:07 AM
  5. Seal buckeld on boot!
    By sprocket in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2008, 05:26 PM
