My BCM circut board has shorted due to what looks like water getting in there. And wont allow the car to start. Whats else is needed to replaced it? key heads?
You will need a BCM of same level LOW, MID, LUX or HIGH you will see the sticker on your BCM, do not use a higher level BCM unless you are wanting to upgrade to climate control etc (if your car isnt already fitted with it) but that would require you to change the entire Loom and ECU to get the extra features and Yes you will need the key heads for the new BCM or get your current heads recoded to suit.
And I almost forgot if you have a VR you need the BCM from a VR, there are differences in the pin outs from VR to VS (at least that is what I have heard)
Someone may correct me on this if I am wrong.
can not recode keys there a one time only thing to a particular bcm
Originally Posted by Adam Savage (mythbusters)
thanks for the correction, what about new heads can they be coded to a BCM?
