Results 1 to 15 of 15
Thread: Fuel smell in cabin
    wickann15's Avatar
    wickann15 is offline YEEHAAAAAAAH
    VS HSV Clubsport
    Jul 2010
    Queensland
    Default Fuel smell in cabin
    Just bought the missus a VS ute and the cabin smells like petrol. Nothing seems to be leaking on the driveway and you can't smell it from outside the car. Besides the option of petrol possibly having been spilled on the carpet what else could be the culprit?
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    wickann15's Avatar
    VS HSV Clubsport
    Jul 2010
    Queensland
    Its only faint while driving but is pretty strong after just being started.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Check the fittings at each end of the fuel rails.
    The O rings on these fittings have been known to leak.
    You may see a stain where the fuel has been leaking.
    PS Nice fiddyfive in your avatar!
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    This happens to me to man, but only once the car has been sitting for a while or overnight with windows up, and a little when the engine is cold, once it warms up it goes away, ive got no leaks or nothing (that i know of) lol
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    wickann15's Avatar
    VS HSV Clubsport
    Jul 2010
    Queensland
    Yeah that sounds about what this one does. Only really stinks after its been sitting for ages and you start it up. Was just a bit concerned cause the missus's previous VS ute never did it
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Red78 View Post
    oh ok yeah i got no idea what it is and prob will never find out lol maybe the person who buys the ute will figure it out
    VS S Series III 1999 Ute
    Nov 2008
    had the same problem in my ute, open the fuel hatch in the tray (big plate 20 screws or something) and re-connect all the fittings, fixed it for me.
    if that dosnt fix your problem check your carbon container (black tube thingo under the bonnet) and re-connect all those fittings.
    also when putting the fuel hactch back on i recommend putting down some new silicone and new screws also give it a good clean out
    cheers, torque
    VSII Ute
    Feb 2010
    WA
    Another possibility is the fuel pump or sender on the tank. Possibly the previous owner has replaced them. They have to be put back with new bolts coated with sealant. Furthermore they need the correct torque.
    Too little and the gasket leaks. If overtightened, the sealant is ruptured. You can remove the access plate behind the driver's seat, or lift up the cargo floor, and feel the front of the tank where the pipes come
    out to see if it is weeping petrol. But if the tank is nearly empty, it will not leak there.
    VR V6 UTE
    Mar 2010
    Quote Originally Posted by jeepster View Post
    Mine is doing the same thing, (access plate behind the seat ) didnt know that was there! should make it easier to check the lines to the tank
    Cheers jeepster.
    VT V8 Calais
    Mar 2007
    Another option (which was my issue) was the fuel hoses had perished in the engine bay (on the return line in my case). The mechanic said the only time they saw it was under pressure, fixed with a cheap bit of fuel hose.
    50LTRv8
    VR V6 UTE
    Mar 2010
    After reading this thred, I thought I would go and attack mine, and found the problem, after removing the access plate behind the drivers seat,
    looking right at me was 3 hoses, 2 go to the fuel tank and the other ( smaller hose, which was cut off ) is the fuel vapour line that goes from the carbon canister
    to the fuel filler neck. As this was not connected Im guessing that the fuel smell, in my case, was coming from the fuel filler neck, and driving with the window down causes it to get sucked into the cabin bad bad bad. Haven't taken it for a drive yet but hoping that its fixed the problem.
    Not sure if yours is the same problem but might be worth a look.
    VR V6 UTE
    Mar 2010
    1998 VS Ute
    Jul 2010
    Perth Hills
    have the same thing with my vs ute now and again, seems to have got better since i first got it yet i havnt done anything to it? dont know what it was so im no help
  15. #15
    A bicycle
    Aug 2009
    Gippsland, Victoria
    have you pulled the cover off the tray to get to the fuel tank? my tank had a crack in it around one of the breather lines, bit of quick-steel fixed it all up though.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
  1. Cabin Fuel Smell
    By NIVSSZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-01-2010, 03:22 AM
  2. Bad fuel smell coming into the cabin..
    By Smoked in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-10-2009, 10:09 AM
  3. bad fuel smell in cabin
    By camvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2009, 08:54 AM
  4. vr fuel smell in cabin
    By vr piggy bank in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2009, 08:48 PM
  5. 96 VS UTE - Fuel smell in cabin
    By cleggy88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2006, 09:57 PM
