Results 1 to 3 of 3
Thread: automatic box, hessitation
    202injected's Avatar
    202injected is offline Quality Engine Builder
    VZ Exec. 3.6
    Oct 2005
    Default automatic box, hessitation
    i have tried searching the forum, but couldn't find the info i am looking for.
    I have a v6 vr exec with auto, when i put the sucker into drive, it takes ages for the gear to acctually engage, does anyone know what the cause of this is, before i pull the box apart to have a look
    i have recently put a minor service kit in the bock while i was rebuilding the engine, the shift issue was there before the engine was out.
    i just wanna know what parts i need before i pull the box out again really
    HUNTERMOTASPORT
    Mild To Wild, Your Engine to Your Budget
    no more VK cancer got the better of her R.I.P.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It's normal to have a slight delay when going from N to D....it is actually mentioned in the owners handbook. When it takes longer than 3 seconds I would start to worry as it usually indicates the clutches etc are very worn and the box needs a full overhaul. There are some good sites which explain full teardown procedures for the 4L60E box....check on GOOGLE.
    Good Luck.
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    have you scanned the box if any fualt codes come up you may have to pull it apart
    tools you will need
    screw driver flat and philp's
    shifta big and small
    hammer or as i reffer to it bang stick
    maby some pliers to
    oh and a super cheap socket set
  1. V6 Automatic Transmission
    By thestig in forum Parts And Other Items For Sale
    Last Post: 10-09-2008, 01:36 PM
  2. VN Automatic transmission
    By llama in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2007, 10:05 AM
  3. Pod Filter on VS V6 Automatic
    By TheTeng in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 08:51 AM
  4. automatic tranmission
    By n1tr0us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2006, 01:25 AM
  5. automatic engine fan
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2006, 12:37 PM
