well i got a mechanic to come around the other day,to do a roadworthy.and he failed me for ,among a few other thing,power steering rack.now i have already had to replace my pump because of a leak,i got under the car and degreased it ,couldnt find anywhere leaking on 1 of the rubber boots there was a bit of seeping but im not sure if it just old fluid from my pump wat should i do to get it passed the roadworthy?
Did he fail it because the rack is leaking or because it is worn and loose? If it's because it's leaking just degrease it and take it back telling him you fixed the leak. If it gets oil on it too quick for that you will need to find the leak it may be the low pressure return hose where it connects to the rack, it is a common point for these to leak. If the actual rack is leaking then you will need to replace the seals in it or get another rack.
