Results 1 to 4 of 4
Thread: Drivers central locking door getting stuck?
    vr executive
    Nov 2008
    Default Drivers central locking door getting stuck?
    hey guys
    when i go to lock my car with the remote central locking all the doors lock except for the drivers one it goes down a tiny bit and gets stuck. i can unlock it and lock it by hand but when i use the button on the key it gets stuck.
    can i fix it?
    cheers
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    I had the same problem today, took the door card off to have a look then it started working again
    VS SS
    Aug 2010
    ACT
    I have a similar problem with my rear drivers side door with the lock only occasionally working, apparently a quick fix is a bit of wd40 to help ease things along on the shaft I think (I haven't pulled the door apart to look yet). Or you can just get another actuator from the wreckers or ebay, I think they average like 25 bucks but I'd pull the door apart to make sure first.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Must be a common problem, happens to my rear passenger sometimes. All i did was take the door card off, cleaned they roads, lubed the moving / rubbing parts and make sure all wires had a proper connection and i was good to go again.
  1. Drivers Door Stuck!
    By [ASLYVY] in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-05-2010, 12:20 PM
  2. Central locking drivers door
    By JoshsVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2007, 05:12 PM
  3. Central locking drivers door
    By Thommo77 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 08:58 PM
  4. vs drivers door central locking
    By shyvn6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2006, 09:26 AM
  5. Drivers Side Central Locking
    By menzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2004, 01:59 PM
