i bought a monster tach and wanted to know which colour wire from the dash tacho i can use to piggy back from the back of the dash panel (if possible). the other wires i'm fine with... oh its a VS s3 v8.
why do u need an aftermarket tacho if it was already fitted with one???
displays a higher rev range, eaiser to see quickly, shift light abilitys?
kind of like goign from a 15" computer screen to a 17" same job, just does it better.
as for the original question,
im not sure which wire would allow a piggy back but i suppose the tacho shoulf of given instructions on how to hook it up if the car never had a tach.
attn Über geeks, i play Second life. Patrio Graysmark.
whats tacho
sorry abit off topic does any one know where they make digital tachos? like a turbo timer or something????? Than would be so FN sweet to have!
aZk.
Passenger side strut tower in engine bay should be a brown wire taped back, Use that wire to get tacho signal
MaT
Originally Posted by garth
I guess he wants to do it like mine, saves running wiring into the engine bay. Mine is wired in just before the dash pickup. If I can be stuffed ill check which one it was later. All we did with mine was to use a multimeter and rev the car, you will notice a change in voltage in relation to revs if you have the right one.Originally Posted by HoZy
AirStrike![]()
Selling FG G6E Turbo and buying a N/A Supra
Look at the back of the cluster on the PCB circuit, It should say what wire is what on the plug sections......
MaT
