Results 1 to 19 of 19
Thread: Grinding noise when i come to a stop.
    95 vs calais V6 Auto
    Aug 2009
    Dora Creek
    Default Grinding noise when i come to a stop.
    Hey guys how are ya's? This arvo i was out driving around and after a little while i noticed that when i brake and come to a complete stop right before the car stops there is a pretty noticable grinding noise and you can feel it in the pedal. I had a quick look around the car but it was getting dark and that so ill have a good look tomorrow, just wondering if anyones got any ideas. Its a vs v6 auto to, Cheers
    Vn
    Nov 2006
    Glen Iris, Vic
    you'll probably find that one of ur pads has worn away down do metal. so its the brake pad metal onto rotor metal and taht your ripping the hell out of you disc, if you have rims that u can put ur hands through just feel both side of the discs all the way round. until you find one thats all rough.. there will be ur culprit. and most likely if your pads were changed at the same time the oppersite side will be at a similar condition..
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Yeah, sounds like its down to the metal.
    Could be from a variety of reasons, though I find most common is when you have a sticky caliper.
    RichoKidd's Avatar
    RichoKidd is offline Obese Commodores
    VT 3.6 2000 Executive
    May 2010
    Perth, WA
    I had this in my old Corolla. It'll be the pads. Change them asap. F***ed rotors is something you DO NOT need. Set you back a bit.
    If your short of cash just get some cheapies as a temp fix. Then go out and get some decent ones come pay day
    Aug 2009
    Dora Creek
    VS S Ute SeriesIII
    Jan 2010
    While you've got the wheels off, check the front hubs for play. Mine had a grinding noise at low speed only when braking. Turned out the left front bearing was shagged. Pricey to fix, but what can you do?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If your brake pad is down to the metal you should be a least machining the discs (rotors) to restore the surface.
    Brakes are not an area where you can afford to cut corners.
    VS Statesman V6
    Jul 2010
    Just replace the discs. Cheaper than a grind. I got mine for $65 each. Simple to replace. And peace of mind that its all new.
    IF IT DONT BURN FOSSIL FUELS, IT AINT A SPORT!
    hq-racing's Avatar
    hq-racing is offline HSVR-28
    93 VR CLUBSPORT WAGON DAILY. 73 HQ PREMIER PROJECT
    Sep 2008
    S.A
    could also be the center bearing or uni's in ur tail shaft..
    VR CLUBSPORT WAGON
    yes a clubsport wagon....
    LIVE THE DREAM
    Aug 2009
    Dora Creek
    Well i pulled the wheels off today and had a good look, everything seems ok, plenty of pad left, front hubs are good.
    Ill have a look at them bearings and that tomorrow.
    Aug 2009
    Dora Creek
    Any other ideas floatin round out there? so far everything looks and feels good. The noise is like when your in a manual and you go to put it in gear without the clutch in, like a grinding crunching noise but its only on that last sec before you completely stop.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Did you remove the calipers and inspect both sides of the discs and all the pads on the friction side?
    Sometimes the pads wear with taper (sticking caliper slides) and look OK from the top.
    Aug 2009
    Dora Creek
    Naa i didnt remove the calipers because i could see the pads from the sides aswell as the top and i just spun the discs around and made sure they werent scratched up and that.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    How much pad was left?
    The only way to be 100% is to pull the calipers off.
  15. #15
    slepar's Avatar
    slepar is offline omg duz it like...dose??
    vn ss
    Mar 2007
    couldnt hurt to change the pads anyway? there not expensive, i will bet that its the pad, ive had this problem a few times
    doin skids for the kids and doughnuts for the grown ups
  16. #16
    Aug 2009
    Dora Creek
    From memory i'd say there'd be roughly 5-7mm of pad left all round they were done bit over a year ago for rego, but yeah ill have another look tomorrow. Cheers
  17. #17
    hq-racing's Avatar
    Sep 2008
    S.A
    it sounds like what mine does and mines the center bearing in my tail-shaft.
    VR CLUBSPORT WAGON
    LIVE THE DREAM
  18. #18
    Aug 2009
    Dora Creek
    Hey guys just thought i'd let you know i took the car to my mechanic and its abs feedback cause the abs module is on its way out. Cheers
  19. #19
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Thanks for the info.
    Never heard of that one before!
  1. Grinding noise
    By crackles23 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2010, 01:08 AM
  2. grinding noise....:(
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2009, 12:15 AM
  3. grinding noise
    By ned in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-02-2009, 11:06 AM
  4. grinding noise
    By reggie_c2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2009, 08:40 PM
  5. bad Grinding noise
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2008, 07:51 PM
