Results 1 to 3 of 3
Thread: Purge hose is blocked with a bolt after engine swap
    VSII Ute
    Feb 2010
    WA
    Angry Purge hose is blocked with a bolt after engine swap
    My V6 was dying, so I got a wrecker to replace it with a low-mileage unit. A few days later,
    I was investigating a problem, and noticed that the purge hose (which is under the throttle)
    was cut and blocked with a bolt. When revving the engine, I hear a faint whistle, so it is
    sucking air and needs to be fixed. Also the piece of hose was pointing forward instead of
    back. I tried calling the bloke who fitted the motor, but he was not at work today.
    Now I wonder why this was done. Maybe the hose was damaged.
    Also the vehicle has LPG conversion. Is this some dodgy bush mechanics trick for LPG
    on the Ecotec?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    I assume thats the hose from the manifold to throttle body ? Don't know why LPG would require that, so maybe get a new piece of hose and try hooking it up properly. Try sneak a peak at another VS with LPG if you can find one.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Do you mean the canister purge or the crankcase breather? I think its pretty standard to block it off when doing and lpg conversion, saves filling the inside of your engine up with gas.
  1. Purge Hose help
    By jluda2099 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2009, 04:04 PM
  2. Purge hose connection
    By gjvz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-07-2009, 10:13 AM
  3. Fixed Purge Hose, Now Stalling?
    By 003KWK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2009, 04:18 PM
  4. [VIC] WANTED/SWAP: 8 bolt S2 VN-VR Flywheel
    By azzfox in forum Swap / Wanted to Buy / Trade
    Last Post: 24-02-2009, 11:07 PM
