Results 1 to 5 of 5
Thread: Fault codes, 44, 76 and 97..
    Vs Equipe
    Aug 2010
    Ipswich
    Default Fault codes, 44, 76 and 97..
    ok guys, i need some help here, as the title says I'm getting a few fault codes i know what they are, i just don't know how to fix them, which is the bit i need help with..
    44, Right hand side O2 sensor lean..
    76, A/F ratio variation between left and right banks (obviously related to 44)..
    97, Canister Purge Solenoid and/or Circuit (this one i have no idea about)..
    so how do i go about fixing what i see as the main problem of the right hand bank leaning out, if its even that, is there a way i can test the O2 sensor to see if its faulty first? if it isn't the O2 sensor how do i go about correcting the A/F ratio..
    and lastly, what the hell do i check for 97, I'm assuming its something to do with the charcoal canister, I'm probably wrong though, i didn't even know there was any kind of electronics associated with it..
    thank you in advance to anyone that's able to help me with these problems..
    VS_Pete_1's Avatar
    VS_Pete_1 is online now Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Vs Equipe
    Aug 2010
    Ipswich
    yeah, i checked all the vacuum hoses i could find, all were attached how they are meant to be..
    im more concerned about the codes telling me its leaning out on 1 side..
    Vs Equipe
    Aug 2010
    Ipswich
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    I would have said the bellmouth has been taken out by someone trying to get more performance out of it, except its an emotec isnt it? I think only the buicks had bellmouths?
    People take the bellmouths out to get more air in, but all it does it lean out the engine on two cylinders.
    I'd say just replace BOTH O2 sensors, not just the faulty one. If the engine has done 100,000+ kms, it would be time to replace your O2 sensors anyway as they're most likely originals, its worth the money as you'll normally notice improved fuel economy as well. My guess is this would probably fix your problems, maybe not code 97, but who knows? You can go from there.
    Also, its not unknown for K&N filters to cause code 76 for some reason..
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  1. vs fault codes 23 and 63?
    By jonboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 03:32 PM
  2. vn v6 fault codes
    By andy71 in forum General
    Last Post: 10-12-2006, 06:56 PM
  3. Fault Codes 23 and 32 HELP
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2006, 06:39 AM
  4. Fault codes
    By ExecVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-11-2005, 07:27 PM
  5. vr fault codes
    By vlcalaisturbo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2005, 01:17 AM
