Results 1 to 5 of 5
Thread: changing a vs berlina lsd diff centre?
    Jan 2008
    Default changing a vs berlina lsd diff centre?
    Hi all, i have a VS Berlina and has a shocking , constant whine coming from the diff. I have been told that it is the diff. Was wondering if anyone had instructios on how to replace the centre. I have replaced diffs before but not a LSD, and from what i see they dont just bolt out. I have a workshop manual but cant find the section on it. any help is appreciated. Thanks
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    VS
    Jul 2010
    Sunshine Coast, Queensland
    If you do want to replace the centre its just the same as an open. Rebuilding it is abit different tho. It depends what the whine is, weather is the crown or pinon or the bearings. Changing either the gears or bearings requires you to get it all alined about with minimal bash lash (if open) or very tight (if lsd) and make sure the gears mark up fine. Takes alot of ####ing around and shims. In my opinion get a diff specialist to do it, or just buy a rebuild one. IRS LSD in a houses all ready marked up and tight will set you back around $500 to $600 while a rebuild will set you back around that before you pay for new gears (if thats the problem). Hope this helps.
    Jan 2008
    Jan 2008
    someone said its as easy as pulling old centre out, new one in. Surely u would have the axles out
  1. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  2. IRS Diff Centre??
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2009, 05:38 PM
  3. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
  4. IRD LSD Centre changing
    By 98berlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2007, 11:26 AM
  5. LSD Diff centre
    By defa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2006, 12:08 PM
