Results 1 to 12 of 12
Thread: VS Central locking problem
    wickann15's Avatar
    wickann15 is offline YEEHAAAAAAAH
    VS HSV Clubsport
    Jul 2010
    Queensland
    Default VS Central locking problem
    Hi having problems with the missus' VS ute. The central locking isn't working and I hoped that it was a flat battery in the key but after getting the key replaced thats obviously not the problem. I also checked the fuse but that seems fine too. I really don't want to have to take it to the auto electricians so if anyone has any ideas on what the problem could be and how to fix it (without replacing the entire thing) I would greatly appreciate it.
    VE Berlina
    Feb 2010
    Melbourne, VIC
    Quote Originally Posted by Red78 View Post
    What seems to be the problem mate? One or both doors not locking or unlocking when you use the remote?
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    Take the door cards off (with care) and unhook the locking motors but leave them in the door and pluged in then try locking, unlocking and watch to see if they try to move (lock Unlock). If they work fine there them look at the conecting rods to see if they are free to move etc or if the motors dont try to move pull them out and get new ones.
    wickann15's Avatar
    VS HSV Clubsport
    Jul 2010
    Queensland
    Quote Originally Posted by Pickled View Post
    Both doors won't lock or unlock when using the remote.
    RazzaCaine is offline Long Gone Now
    Mar 2010
    as i recently found out in another thread on here, not all the utes came out with central locking but despite this holden still supplied them with the remote control key head. as waffen ss said, take the door cards off and firstly check to see if you have central locking on the car. if you do then do as waffen ss said and check the motors etc to see if they are still working etc
    wickann15's Avatar
    VS HSV Clubsport
    Jul 2010
    Queensland
    VY Crewman SS / VR V8 Berlina sedan / VP V8 Wagon
    Jun 2009
    Hi guys i have a VR series 2 Berlina all my doors none of the locking motors work in any door up or down they dont work with key remote and dont work by using the key blade in the drivers door the fuse is not blown i changed the drivers central locking motor still nothing i have changed the BCM from another vr berlina i have that i know works but still nothing lol any help would be nice .
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Maybe try reprogramming the key to the BCM? I think you hold the key in the ignition and hold the unlock button down, i cant remember how to do it, but thats an option to try.
    95 Holden Commodore VS Ute
    Mar 2010
    Perth W.A
    Hey mate what model is the Vs ute? i have a series 1 vs but it appears not to have central locking just the keys with the button
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by ChappyVS95 View Post
    It mentions a bit about the central locking in series 1 utes in the gregorys workshop manual.Under the BCM (Body Control Module) section,it mentions that the low series BCM that is fitted to utility,executive,acclaim,S, and CSI models,controls the following functions,central door locking(except series 1 utility),washer timer,theft deterrent systems,courtesy lamp delay,automatic lights off,and if applicable,cruise control and power windows.It goes on to say the following-
    The high series BCM controls the same as the low series BCM ,but with the following extra functions,Variable windscreen wiper delay,power aerial,speed sensitive power steering,(calais,newport and statesman),instrument lamp dimmer,automatic lamps off with delay,rear lamp failure warning,rear demister,engine cooling fan low speed relay,and theft deterrent systems.
    Looking at this,Id say the series 1 utilitys did not have central locking available as on option.It would be interesting to see if any of the wiring was still fitted to these utes,and to see if the original BCM could support central locking if the power door locks and wiring was fitted up etc..
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    When manually pressing the drivers door lock button up or down do anything to the passenger door?
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Demonica's Avatar
    Demonica is offline Mrs Wraith
    VS clubby
    Mar 2010
    SE Qld
    Hey fellas- it's my ute that Red78 is talking about lol. It's a series 3 VS S so remote central locking should actually be standard on it. Not happy at all after spending $220 on new keys for it (I was hoping the key's bettery was the problem)
    Tried putting the key in the door and pressing the buttons as it was suggested and nothing has changed, the remote central locking still doesn't work
    Markovr- when manually pressing up or down the drivers door lock the passenger one doesn't do a thing. Passenger lock won't even go down if the door is open so have been locking it from the inside then use the key to lock the drivers door. Real pain in the arse.
  1. Central Locking Problem
    By SteveB62 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2012, 11:46 AM
  2. Vr central locking problem
    By Pickle' in forum Electrical Wiring / Questions
    Last Post: 17-05-2009, 08:40 PM
  3. (Another) VR Central Locking Problem
    By Riff88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2007, 12:51 AM
  4. Central Locking Problem
    By Vs_sharlene in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 08:57 PM
  5. Central Locking Problem
    By pegga in forum Electrical Wiring / Questions
    Last Post: 25-12-2005, 10:07 PM
