Results 1 to 12 of 12
Thread: Converting, well Converted my VR BT1 to Ecotec V6..
    VR, VX, VN Commodore's
    Dec 2008
    Default Converting, well Converted my VR BT1 to Ecotec V6..
    as the title states, my buick decided to blow up on the weekend, got a hold of a written off VS and pulled the motor n ecu and wiring loom etc out of that and put in the VR. changed all the pwr steerin lines n heater pipes etc so its all ready to go in... but ive heard i might need to change the BCM? one thing, what is a BCM, where is it, and how hard is it to change, and does anyone have any instructions?
    something about the VS ECU wont talk or communicate to my VR's BCM and ill need to swap them over?
    its not a problem because ive got a whole VS to do it with, so its just the matter of swapping it over but i dont know what it is or where it is haha
    any help would be much appreaciated, cheers.. Michael
    Dont Take Life Too Seriously, You Never Get Out Alive Anyways.
    2002 Series II VX SS - 6spd - 5.7L - Black - Red Leather <3
    VnExecutive
    Mar 2007
    Cranbourne
    the bcm is up under the steering wheel from memory, and the vs key will become the key for you vr if you change the bcms too i think??
    LIFES A GARDEN, DIG IT..lol
    Dec 2008
    yeah cheers mate
    i heard i have to change them so the car would run etc :S
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    BCM is body control module. Not sure exactly how it relates to the key and ECU, except that upmarket models had High range(?) BCM's and Equipes and cheaper models had low range(?) BCM's, it was all to do with whether it had electric windows and climate control and such, but if you're doing the conversion it would be better to go the whole hog and get an ecotec BCM instead of trying to mismatch parts like that.
    Similar to when people do Auto to manual conversions but still use the auto loom instead of getting a manual one, then wonder why the car keeps stalling? go figure. Do it right the first time.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Dec 2009
    I'd be checking with Holden about the VR's BCM compatability with the VS ECU. If it sends the same type of signal to the ECU to allow it to start the engine then I'd guess you just need to get the codes matched otherwise you will need a VS BCM probably of the same level and it's key head to put on your old key tang. You can probably then get your old keys recoded to suit if there any good?
    Dec 2008
    yeah cheers guys, think ill put the VS BCM in the VR and then use the VS button heads..
    does anyone have a pic of a BCM so i know what im looking for? cheers
    Dec 2008
    found the BCM
    Now.. Theres 2 connectors on the ecotecs injectors, well i think thats where they goto, the connectors go on to some wires that come out of the loom that goes to the headlights n indicators etc... do i really have to change that whole loom on the drivers side that goes to the headlights n indicators etc? or can i trace those 2 connectors that goto the injectors down the loom and cut them out the loom separatly and put into my VR? or will i have to use the whole VS loom?
    i hope that made sence
    heres a pic of the connectors im talking about, and also the pic of the motor, Now that does look alot better then the buick
    Attached Thumbnails Attached Thumbnails Converting, well Converted my VR BT1 to Ecotec V6..-100816_201128.jpg   Converting, well Converted my VR BT1 to Ecotec V6..-100816_185559.jpg
    Dec 2008
    im actually unsure if they goto the injectors or not, it was dark when i looked, but in the pic you can see what ones im talking about
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    they feed everything ecu injectors coils tacho and oil light temp etc the vr they plug i down near the battery vs its up there near the firewall
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    and don't just plug the vs bcm straight in. needs to be rewired, because the pinouts are different.
    Dec 2008
    Cheers Delco,, had me stressing about that for a minute, but cheers for clearin that up
    Quote Originally Posted by wamboin23 View Post
    Hey,, are there instructions or do i just need a wiring diagram to re wire it? or does it have to be done professionally? cheers
    PS: Electricals arent my thing, im more mechanical, thats easy for me, its the electrics that slow me down
    Dec 2008
    Got it all worked out, found a sheet showing me how to re-wire the BCM and thats all ive got to do so she should be good to go after the re-wiring!
    cheers for all your help, much appreaciated
  1. vr converted to vs ecotec..keeps blowing transmissions fuse
    By holden_fan771708 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2010, 08:16 PM
  2. converting a vs v6 ecotec motor into my vr commodore
    By steven45 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2010, 07:29 PM
  3. Converting Supercharged Ecotec to manual?
    By Torrie_Man in forum General Discussion
    Last Post: 30-05-2009, 12:15 PM
  4. VS V8 converting to a VT Ecotec V6
    By beckcarlos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2008, 08:30 AM
  5. converting VS Ecotec 3.8ltr to VR 3.8ltr
    By ^Porter^ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2005, 02:18 AM
