As above... got a set of Kings springs sitting in the garage gathering dust, from back when I owned my VT.
Just curious to know if I can use them in the VR, before I go pulling the car apart.
From what I've heard and I'm only taking it as gospel at the moment, they can be used - but I just want to be certain.
Thanks.
Also, IRS rear springs between the VR and the VT are the same too yeah? Pretty sure they are...
Yeah they will fit, i put VT front shocks and Springs in my old VS, no idea about rear IRS though.
Sweet, thought they were the same, thanks for clearing that up![]()
ok a guide vb-vp the same vr-vz the same ve is differnt some would even say vb-vz springs can be interchanged but dont try it
I knew VP-VR was different (well, VN and VR), as the VN has the ball joint at the bottom of the shock.
Getting a set of VX2 FE2 struts in the next few days, going to whack them and a full set of Kings SL's into the VR and see if it makes it a much nicer car to drive.
