Results 1 to 23 of 23
Thread: Boot Lid full of water
    VS SS S2
    Aug 2010
    Melton
    Default Boot Lid full of water
    Hi guys,
    After it rains for a while, my boot lid gets full of water. I am guessing it is coming in around the lights. Is it still possible to get new seals for the lights?
    Cheers,
    RevSS.
    92 VP Series 2
    Jan 2009
    East Brisbane
    I got some stuff from bunnings when my vp did that, worked a treat, also used some between the rear spoiler and the bootlid. It comes in a roll about 8mm-9mm thick and kinda feels and looks like foam. Sorry I couldnt help more, maybe ask someone at bunnings and they may know what im talking about lol, i've forgotten what its called. Good luck mate
    VS SS S2
    Aug 2010
    Melton
    Thanks mate.
    I did get some foam weather seal that seemed to fix it for a month or so.. but the leaks are back. I was wondering about the real spoiler and if it could leak from there. Didn't think it could. So might have to have a go at that too.
    Any other ideas guys??
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Mine does it too, I just sealed up some holes but it still leaks. Only after heavy rain though.
    I guess sealing up the taillights and re-sealing the rear-quart windows are next up.
    VS SS S2
    Aug 2010
    Melton
    I have read about the rear-quart windows but the boot itself does not have water, it is just the bootlid itself that fills up. You open the boot and water comes out the holes (which look like drain holes so maybe Holden knew about this) along the bottom of the lid.
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    There are drain holes that have been blocked up by Holden when they manufactured the cars (THIS IS ON A VT MIND YOU) lift the boot lid up, now look for two little bumps one on either end of the boot, located near the corner of the lid itself (Imagine that when the boot lid itself is closed these holes will be facing straight down). If you see them get something sharp and try to poke a hole in it, it should be easy if you've found the right spot (and if it's the same as a VT) as there will be putty that's been painted over.
    Remove all the putty, if it's the same as a VT you will now never get water coming out of you're boot when you lift it up.
    Cheers Glenn.
    VS SS S2
    Aug 2010
    Melton
    I know there are holes each end that seem like drain holes.. Will have to have a look again. But would rather fix the problem than ways around it.
    Cheers,
    Brad.
    VS 5 Litre BT1
    Jul 2006
    Mine was doing the same thing some time ago.
    I replaced the brake light LED in the spoiler and need to remove the spoler to get to it. Since re-attaching the spoiler and tightening up the centre bolt, the leak seems to have disappeared in mine so maybe check that yours is tight and not letting any water in there.
    VS SS S2
    Aug 2010
    Melton
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    yeah the seals for the taillights in the bootlid might be shot. it happened to me before with the same symptoms u described. as far as i know holden still sell the seals but only for one side.
    thats no drama, buy 2 of them and one will stick to the taillight, on the other side u will have to flip the seal over and stick to the bootlid itself. just take ya time and get it right (there will probably be guide marks on the bootlid from the previous seal anyway)
    that fixed mine but then again i haven't got a spoiler
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VS SS S2
    Aug 2010
    Melton
    Was it a few years ago you replaced your Dirt drifter? As I have been told by a Holden spare parts dealer that they stopped making them about 2-3 years ago
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    Easy way is to get some clear silicone and go round all the bolts on the lights and make sure you do the strip that holds the number plate lights as well, Take the nuts off and put some goo on then put the nuts back on. 2 years running and mine is still dry.
    VS SS
    Aug 2010
    ACT
    Silicon is how I fixed mine, the water was getting through where the wiring for the LED in the spoiler is so I filled that up, and put a light ring where the seals should be. But watch out for the silicon squishing out from under it when you tighten the spoiler back on if you do that.
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Quote Originally Posted by RevSS View Post
    Cheers,
    Brad.
    Mate I'm not sure if you read my post properly, I said the boot has proper drain holes, that have been blocked up and painted over, you cannot see these holes. Not the two holes on the inside of the boot lid itself.
    The water still gets into the boot lid but goes straight out the bottom of it, so it's never there.
    Sorry if the VS is different to the VT boot lid.
  15. #15
    VS 5L M5 VS 6L M6
    Apr 2009
    it would have been early-mid 09 when i got them, its ridiculous every time i go to get genuine parts nowadays they tell me its obsolete already!
    Avoid cluey police
  16. #16
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
  17. #17
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
  18. #18
    VS statesman
    Nov 2010
    melb
    im a panel beater and if something has a boot leak the best is to seal it with proper sealer or window sealer if your after something for around the tail lights.
  19. #19
    VR Executive
    Nov 2009
    happens on all these model cars (holdens), i used to work for holden and the was a techline about it. u drill a small hole each side of the boot lid in the corners (u will see the spot when you look next), use like a 3-4mm drill bit and it works sweet, finally did it to mine a month or so ago and haven't had a problem since.
  20. #20
    Jaymz's Avatar
    Jaymz is online now Donating Member
    VS Exec 1996
    May 2005
    Hamilton, NZ
    Creating drainage holes (whether they are supposed to be there or not) isn't really a "fix" for the problem. More of a bandaid solution.
    You need to find out how to stop the water getting into the boot lid in the first place. Just letting the water run through is asking for failed bulbs/rust in the future (unless all your bolts/nuts/wires and rust proofed)
    Personally I would go with the siliconed bolt holes and tightened nuts to fix the problem.
    Other option is to get a mate in the boot with a light and slowly run water over the boot to isolate the location the water is getting in. You should be able to see drips from the inside. If you do try this, start at the bottom and work your way up, otherwise you wont know where it is coming from!
    Good luck! Leaks are a pain in the a$$!!!
  21. #21
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    ^^ I have heard of people jumping in there boot to see where it is coming from, but if it's only leaking into the boot lid eg: (every time you lift the boot lid up water comes out) you will not see how it gets into there in the first place.
  22. #22
    Jaymz's Avatar
    VS Exec 1996
    May 2005
    Hamilton, NZ
    Quote Originally Posted by G.C.Photography View Post
    Might be a bit different in the VT (I havent seen the inside of their boots), but definately in the VS the inside of the boot lid has quite a few access panels/holes that you can see through to get to all the bolts and nuts holding the exterier on. If it is leaking from these bolts it should be reasonably easy to see if water is coming in there.
  23. #23
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Sounds like it is then mate sorry!!
  1. Replies: 10
    Last Post: 30-06-2010, 09:29 AM
  2. a tail light full of water!
    By Tony. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2010, 02:46 PM
  3. Sump, full of water?
    By vxclubby in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2009, 02:08 PM
  4. Number plate light full of water
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2006, 06:07 PM
  5. water in boot
    By dale s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2006, 01:21 AM
