Hey guys, I'm looking for opinions and information on modifying my 96' VS 3.8L Ecotec. Currently has a straight through (w/ Cat) 2.5" Exhaust, Pacemaker Extractors, CAI and running on BP Ultimate.
I plan on adding a Cam, Rollers, Decent Exhaust and Memcal.
I've been looking at the Wade website and like this particular profile.
What do you guys think? There's another profile for mod chip and exhaust, would I be better off with that? I want to get a nice sound from the car, but I still need it to be my daily driver, I don't want a cam to big so it's like a slug at low RPM which it already is a little.Profile# 992a
Lobe Lift In .295
Timing Ad Open Close 25-71
Duration @.050 214
Valve Clr Hyd
Valve Lift .472
Lobe Set 112
Power increase, needs chip
Wade Cams Australia precision camshafts for automotive, marine, aviation, industry
Found under Popular Profiles, "Holden V6 3.8 Roller".
I'm also liking the Yella Terra Rockers, but I don't know heaps about this stuff in particular so that's why I need help. :P
For Memcal I was thinking.Part No.
YT 6669
Type
Roller rocker set - Australia only
Product name
Yella Terra (bolt on non adjustable)
Yella Terra Ultra light bolt on non-adjustable 1.61:1. Suits S/C and N/A engines, clears factory valve covers. Designed for use with after market high lift camshaft, for standard camshaft use higher ratio for improved performance.
Yella Terra - Part details
What do you guys think?ChipTorque
HP3 Performance Memcal
Aftermarket tune with corrections in fuel and timing to provide performance tune enhancements for aftermarket modifications at the level of a sports exhaust system, aftermarket extractors, mild camshaft or higher ratio roller rockers and higher octane fuel.
ChipTorque Performance - VS-VT V6 Ecotec
