Results 1 to 11 of 11
Thread: removing springs
    MUNTED6 is offline Banned
    vn berlina
    Apr 2007
    Default removing springs
    Hi guys im just wondering if anyone could help me. ive just brought a pair of lowered king springs IRS i got a problem i havent got any spring clamps so was wondering if anyone know of any other way of removing the springs n fitting with the clamps. cheeerz much appriciate ya help
    Bagged vs caprice sII
    Sep 2007
    Newcastle
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Clamps make it easier but as said you can always undo the shocks and get them out that way.
    vn berlina
    Apr 2007
    oh ok thanx for that, so if i undo the shocks the spring will come to looose?
    VZ SV6
    Oct 2008
    Victoria, Melbourne,Croydon
    So what if you were doing the fronts is there a way around it without clamps?
    vr berlina
    Aug 2010
    australia
    no srry there isent unless there lowerd
    edit lowerd fronts have like no trap or seat pressure
    VZ SV6
    Oct 2008
    so if i was changing out a stock strut and spring for a lowered strut and spring the clamps would be needed
    vr berlina
    Aug 2010
    australia
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Actually, you can do the front without spring compressors.. simply remove the top shock nut with car still on ground, when you jack it up, all the weight will come off the spring and uncompress it. lowered springs generally dont need spring compressors to install onto the struts. Personally have not tried it but cant see why it wouldnt work this way
    Power is measured in DECIBEL
    Mistikal's Avatar
    Mistikal is offline Hoon in a Deluxe Pack
    WH Into, VR Acclaim
    Jan 2006
    Redcliffe, WA
    With the rears, undo the bottom shock bolt, usually easier than attempting the top bolt. I found that it's easier to jack the bottom of the shock ever so slightly (makes it a little easier to undo), and to also have a friend stand with their foot on the rotor applying a little downward pressure to stop the shock from compressing when undoing the bolt.
    When I tried to undo the top bolt of the shock instead, the shock just spun (like undoing a nut without holding onto the bolt-head).
  1. Removing Rear Springs
    By VN Lukey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 07:56 PM
  2. removing rear springs in vx??
    By ANDREASVX87 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2008, 09:26 PM
  3. removing shocks & springs
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2008, 02:46 PM
  4. Removing and Replacing Springs in a VZ
    By SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2008, 07:00 PM
  5. removing springs
    By kozij in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-12-2007, 06:15 PM
