Results 1 to 6 of 6
Thread: Vr Radiator Cracked!!!
    VR Executive V6
    Jun 2010
    Carrum Downs, Victoria
    Wink Vr Radiator Cracked!!!
    hey guys, annoying day ive had. last nite my temp gauge was going up and down dramatically, i assumed, hoping, it was sumtin simple such as low oil or sumtin perhaps a faulty sensor.
    oil was fine.
    but today as i was drivin me n my gf to the cinemas, my temp gauge was just about on H and i thought id pull over n see wots goin on, first thing i noticed was steam coming from the drivers side of the radiator core or wotever its called, and a big splatter of coolant on the radiator fan shield. i looked at where the steam was coming from and the was a massive crack about 10cm long just spewing coolant out.
    so now im guna have to spend 250 bucks to get it replaced, has anyone else had a similar sort of problem? should i be worried bout sumtin else to do with it? ive had the car for bout 4 months n its a 94 vr, the place where it cracked looked fairly corroded so im assuming its the original radiator or very old which is annoyin.
    thought id share my frustration with you all
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    Go get a new one and watch out for the cheap shit, spend $250+ and get one worth having, I put a VS V8 steel job dat I had Recored in mine and added a thermal 16" fan. Its a home built supercharged V6 and can do skids all day and not go over half temp, Bottom line is get a good one from a supplier you or your mates Know or trust and get a new 100kpa (15psi) radiator cap and thermostat.
    VR Acclaim
    Sep 2008
    Kingsley WA
    I suggest you get a new one on eBay. If you can wait a few days for it to be delivered (5 - 6 days to WA, probably less for Victoria), you can pick a new radiator up on eBay for $99.95. I bought one 17 months ago. Delivery to WA was an extra $34.00. I couldn't tell the difference between the new one and the original. I've done 15,000 km since then and it's working as it should.
    VR Executive V6
    Jun 2010
    ye i taking it to a radiator repair place near me, i need my car running asap, i cant bare to go witout it for one day let alone a week, plus id prefer to pay extra to get it installed.
    the place im going to is charging me 250 bucks and from wot ive gotten from other places its fairly cheap.
    cheers guys
    VS acclaim
    Aug 2010
    Mooroolbark
    theres a guy in geelong wholl give a new one for $90 cash... plastic tanks tho
    works a treat in mine
    VR wagon, 5 ltr ski boat,
    Sep 2009
    Broome
    the dif between The Ebay and a Covs $180 is about 4 years... or 18 months for the Ebay and the thin core will crack.. Seen it happen to many times up here with cheeeeppp rads...
  1. Where has your radiator cracked?
    By _R_J_K_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2010, 11:39 PM
  2. Radiator or cracked cylinder head?
    By LMac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 01:24 PM
  3. Cracked Radiator
    By holden_chik in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-03-2008, 08:27 PM
  4. radiator cracked @ servo yesterday
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2007, 12:03 PM
  5. radiator cracked
    By S.T.S in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2005, 05:13 PM
