Results 1 to 5 of 5
Thread: Power antenna
    VS II 5 ltr Berlina Wagon
    Apr 2004
    Default Power antenna
    It goes up and down ok but when it goes to the bottom it still sticks out about an inch now. It's as if it is binding up so I sprayed some silicon on the mast when it was fully extended but it did nothing. So are these things servicable i.e. is the drum that takes up the cord getting gunjed up and be taken apart or is it just simply wearing out ?
    Mmmmm V8
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You can get a replacement mast and the nylon rope that is used to ratchet the aerial up and down, but I've personally never had any success with this on either my VS Calais or my wife's VS Clubsport. Better off buying a replacement aerial and motor unit from SuperCheap etc. You could also try getting a second-hand unit from a wrecker.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Push it down and disconnect it behind the kick panel. More trouble than its worth to replace. Radio pickup is fine when the aerial is down.
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by IBLOWN View Post
    Not much country driving i guess.
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    IBLOWN has that one, Mine has done the same so it got jamed in there to stay and seems to work fine. If your going to play just get a new one and its a shit of a job.
  1. Power Antenna
    By Trayner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2008, 08:28 PM
  2. Power Antenna
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2007, 10:42 AM
  3. Power Antenna
    By VnWag in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2006, 08:09 AM
  4. Power Antenna Help Please?
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2006, 05:52 PM
  5. Power Antenna?
    Last Post: 08-11-2006, 06:47 PM
