Results 1 to 8 of 8
Thread: will vs climate control from a berlina/calais work in an exec?
    VS executive S1
    Aug 2010
    Post will vs climate control from a berlina/calais work in an exec?
    hey guys i have an exec but really like the climate control option from the calais etc. i was wondering if anyone knows how to make it work in an exec. if its possible.. please help..urprise
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Can be done - but you need to change the heater box and the loom.
    and 3 Dangerous non ABS VN's
    VS executive S1
    Aug 2010
    im no mechanic but me and my dad know a bit about cars recon we could takle it?
    R1D0LF1 is offline R1D0LF1
    VS Executive S1
    Jun 2009
    VS executive S1
    Aug 2010
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    It makes life easier when you change the entire body loom over to a higher model but it can be done by splicing into the exec loom. The BCM does not need to be changed over to work.
    88GreenVN did a fantastic write up on how to do the wiring for a VN that I adapted to my VR but tried to use as much of the climate loom as possible
    I was lucky enough to get all the parts out of a wreck a friend had but I would say for what is in the ebay add would be about right.
    It took myself about 1 hour to pull the entire dash and heater box out but practically an entire weekend just to get it all back together. Also remember the A/C needs to be de-gassed before starting and re-gassed when complete.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    88GreenVN's Avatar
    Jun 2006
    $365 may be over the top - should be able to score all the sensors and heater box for under $200. But in the end it wont matter how much you pay as long as it's complete - like includes the loom.
    Sun sensor, ambient sensor, temp sensor on the heater pipes, loom, vac box, lcd screen control, loom to the heater box.
    And go for it, set aside a day or so and have an a/c person ready to re gas the a/c when all back together.
    88GreenVN's Avatar
    Jun 2006
    Just looked at the kit on Ebay and looks to be what you will need - see if you can get the Level 3 cluster chucked in.
  1. climate control into an exec?
    By tufcalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2010, 11:42 PM
  2. climate control,how does it work need to know for climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2010, 12:49 PM
  3. hotwired climate control to work VN
    By sik-holden in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2009, 06:20 PM
  4. CLIMATE control upgrade to VY EXEC
    By sp001in in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-03-2009, 08:20 AM
  5. Climate Control into Exec
    By vsiicalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2007, 09:13 PM
Tags for this Thread
