hey was wondering if the gts fault codes are the same as a normal 5L vr?
Yes they are.
ok so im getting a code 43 for knock sensor, does that mean that the knock sensor is stuffed or there is a knock in the engine?
Knock sensor and/or wiring is fubar. Very common for the wires to overheat and fail as they are tucked right up under the extractors.
Reaper
cool thanks reaper
