Last night when i was driving my car back home, whenever i would indicate or slightly tap the stalk my high beams would turn on. I would either have to hold the stalk or flick it around a few times for them to turn off. Im going to see if it does it again tonight, hopefully it was just one of those one offs since the car has hardly been driven in the last few months
It is fairly common for the indicator stalk to flash the high beam especially when the indicators cancel. Only real fix is a new indicator arm and switch - they're on Ebay new for under $60 and easy to instal. Good Luck.
Thanks for the help hako i'll chuck in a second hand one and see how it goes. If still the same ill buy a new one
Still doing it, but picked up on it. Beams only go on after the right indicator clicks off.
