Results 1 to 3 of 3
Thread: HELP door not locking
    vs III commodore ute
    Sep 2008
    Default HELP door not locking
    ive got a vr ute no central locking. i just use the key in the key hole.
    For some reason the drivers door unlocks with the key but wont lock with the key.
    If i close the door i can lock the door from the inside ( push down on the door thingo) but the door will NOT lock with the key.. but if i hop out the passanger side with the door still locked from inside. i can unlock the drivers door with the key. but not lock
    any ideas?
    My CaR dOsNt ChErP gEaRs, It JuSt KiCkS sIdEwAyS!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Pull the trim off the drivers door and inspect the operation of the lever connected to the back of the door key...maybe its badly worn. Spray everything that moves with lubricant while you're in there.
    Sep 2008
    yeh ive pulled it all apart n taken the barrel to the lock smith. redoing the whole barrel to suit key. he said it was probs just worn.
  1. VZ Door locking Problems
    By rbarn38 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-02-2010, 07:05 PM
  2. Vp Doorkey Remote Fob For Door Locking
    By Lightwing in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2007, 03:11 PM
  3. Door Central Locking
    By Maxie195 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2005, 09:50 PM
  4. Door Central Locking
    By Maxie195 in forum Electrical Wiring / Questions
    Last Post: 04-08-2005, 02:58 PM
  5. Door Not Locking
    By cookie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2005, 08:16 AM
