Results 1 to 7 of 7
Thread: Cruise Control
    VS V8 commodore
    Nov 2009
    perth
    Default Cruise Control
    Hey guys,
    How hard is it to put cruise control onto a VS V8 Exec? just curiouse cause i have a VR V6 berlina with all the good gear on it and wanna put some of it into the VS.
    vx wagon
    Aug 2010
    pakenham
    Lightbulb cruse control
    Had a problem with cruise control not working with lights on.see my thread for more details..
    Fixed it by changing the blown tail/brake light globe. it had shorted to to both circuits $2.oo fix.
    thanks for the advice guys.
    veno
    VS V8 commodore
    Nov 2009
    perth
    hey man.
    nah the cruise control isnt in it yet i want to hook it up but i am unsure how to go about it and how easy iti is to do.
    cheers
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    as far as i know there completely different setups
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    vsspack's Avatar
    vsspack is offline King of the Mang
    VN Mang Machine
    Sep 2007
    Mildura
    You need the indicator stalk, The wiring needs to be there otherwise its not really worth doing.
    I put it in mine after i did a full body loom swap but thats a fairly big job haha.
    So if wiring is there all you need to do is install the crusie/indicator stalk, Install the brake pedal button (this goes in one of hte holes near where the brake button is on the base of the pedal
    and then mount the cruise modual in your engine bay and hook it up to the body loom and the throttle body.
    Its fairly easy if all the wiring is there already for you
    Some say less talk more action. But I rekon more torque less traction!
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    yes the cruise control wiring is the drama ...if it is installed from new the cruise control wiring will be in the main loom all taped together...there were dealer fitted systems however that have just the cruise loom as a complete separate unit...if you could find one of those it would be quite easy to install.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VR Executive
    Jun 2010
    Rockhampton
    Yeah im going thru the same thing-adding all the dealer fitted cruise stuff.I grabbed a MID Series BCM from a VR Berlina in case i can't get it to work,ill get the two key heads and fit the BCM to run it
    The Daily:6/93 VR Executive SedanVQ V8 Long Range Tank L3 Dash Conversion VR Calais Leather Seats VR II Steering Wheel VTSS Mags Aqaumarine in Colour
    The Weekender:6/07 BF XR8 6 Spd Manual Sedan Ego Paint Pedders Coilovers Adj.Swaybars Shelby GT500 Rotating Assembly 2800lb Twin Plate Yella Terra CAI FPV Gauge Pod Full Sports Leather Interior
    Tuned by Glenmore Motors,Rockhampton
    -345RwHp,13.8ET with crappy tires and bulk wheel tramp
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  3. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  4. cruise control no control
    By foxinjox in forum Electrical Wiring / Questions
    Last Post: 16-11-2005, 01:32 PM
