Results 1 to 18 of 18
Thread: Engine light
    MUNTED6 is offline Banned
    vn berlina
    Apr 2007
    Default Engine light
    Hi everyone,
    I got a small problem i neeed to ask for your help, just today i went to pick up my car from the police impound wich the car sat there for 3 days
    I drove on the freeway home and just when i got off the freeway i was driving around the shopping centre then i notice me engine light was on, i wasnt the driver so i wasnt able to notice any change.
    Then i asked my step mum who was driving if theres any differents to the drive, she said n i also notice that when pressing the accelerator it really lacks, how can i explain it, well it kinda revs out n hard to take off, its like driving with any tranny fluid. if u know wat i mean.
    So yh i wanted to ask if anyone knows what the problem is?
    Also if it helps my car is a VS V6 commdoore
    Thanx in advance
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    vn berlina
    Apr 2007
    no havent beeen doing burn outs. The trans is full of fluid, im just hoping its not a blown head gaskit
    92 vp executive v6 auto
    Jan 2010
    deception bay queensland
    ive had the same happen with both my dads and my vr's we could only put it down to low or bad auto fluid
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The lack of power will be due to the car being in LHM (Limp Home Mode) which happen when the engine or transmission develops a severe problem...like overheating coolant or transmission oil, sticking trans solenoids etc etc. In LHM, the car starts and stays in 3rd gear only which makes it feel like it's being powered by a rubber band. . As The1 says, do a codes check and you may get some codes. Another possible temporary "fix" is to disconnect the battery for a few minutes and see if it's still there.
    vn berlina
    Apr 2007
    hi i just checked my engine error light code and the first 3 codes were 12, than after that it said 81 which i checked the codes and it said, 2 - 3 Shift Control Solenoid Fault - Auto Transmission Only---- so what would that mean wrong with the transmission? what will i have to fix, HAKO you were pretty much right
    vn berlina
    Apr 2007
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    That's the solenoid sticking or shorting - can be replaced by a trans shop or yourself - cost about $60 DIY or about $200 at a trans shop. Good Luck.
    Edit - I had the same problem about 2 years ago.
    Edit 2 - here's the post I generated back then: Solenoid replacement 4L60E
    vn berlina
    Apr 2007
    k thanx alot for that just one more help if thats ok, Theres 2 solenoids in the transmission right?? So which one would it be that ill have to replace (2 - 3 Shift Control Solenoid) or will i have to replace both of them... thanx again for ur help
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check this link - read thru it and you'll see the pix of how they remove the solenoid although from the previous link I sent you should be able to identify it by how it looks. GM 4L60E Transmission Rebuild Guide with Pictures, Tips, Pics and Tricks
    Good Luck.
    vn berlina
    Apr 2007
    thank you so much mate you been a big help ill be working on it this weekend and ill let you know on how i go
    vn berlina
    Apr 2007
    I went around today to buy the shift solenoid and repco and mayday didnt have em so they told me to gotto HOLDEN, i went there and the guy said itll cost $150 is that the right price? cos i think its way tơ dear. He said that with the shift solenoid 2nd n 3rd is UP shift is that true? and he said that the 97 model is different to the 96 model. can someone help me out with this please
    vn berlina
    Apr 2007
    k so ive pulled out my tranny sump, inspected both the shidt solenoid and cant seem to c anything rong with it.
    Its not burnt out, the orange cable thingo is clean as anything, so if it looks like its in gd nick wat could b rong with it, cos i dont wanna go spendin $150 on somthing that wont fix me prob.
    N i really cant put everything together to test drive it cos if prob isnt fixed then ill hav to pull apart again n thatll b a big waste of tranny fluid.
    HELLLLPPP PLEASE....
  15. #15
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You will not be able to tell if the solenoid is bad by inspecting it as it probably has shorted internally - you need to measure the resistance of the solenoid, however from the youtube video you should know which is the 2/3 solenoid. Try Ebay for a solenoid....or even wreckers or a trans shop. $150 is way too much.
    Edit:....did an Ebay search and straight up found one for under $50 delivered (or pick up if you're in Sydney) - these come with instructions on how to identify the bad solenoid etc etc.
    http://cgi.ebay.com.au/Shift-Solenoi...ts_Accessories
    Good Luck.
  16. #16
    VQ Caprice II
    Aug 2006
    ebay link... transmission shift solenoid, Cars, Bikes, Boats items at low prices on eBay.com.au
    looks like a common problem.
    hope this helps, all i did in ebay is type "holden transmission selenoid" and bingo a list
  17. #17
    vn berlina
    Apr 2007
    thanks so much uve bêen a big help... ill go have a look round my area for tranny garages... itll be alright if i leave the sump off for the mean time till i get the solenoid? cos the car isnt in the garage.. wont ### the transmission up if bugs go crawlin in there would it? lol
  18. #18
    vn berlina
    Apr 2007
    OMG u wouldnt believe how hard it is to find a shift solenoid in the western suberbs of melbourne, i looked up d yellow pages and called atleast 20 transmission garages and they all said they havent got in stock. Even tried holden and they didnt even have it, but i manage to find one tranny joint but they will order till monday, costing $88
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  3. HELP: VT SS Engine light and oil light coming on
    By Evilkio in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-07-2009, 10:36 PM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
