Results 1 to 2 of 2
Thread: Coolant Smell.
    94 VR Commodore 3.8L V6
    Mar 2010
    Default Coolant Smell.
    Yea, as title says, i have a Slight coolant smell after the my VR has been running. i've been doing some research as to possible causes. possible heatercore on its way out. My temp goes up when sitting in traffic if that helps anyone, ask me if u need more info.
    Cheers.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Temp going up when sitting in traffic is normal - if you smell that sickly coolant smell it certainly sounds like the heater core. At this stage I'd decide if I want to save money or spend some plus time. If the former just add some stop leak to the coolant which will slow/stop the leak for a few months, maybe a year. If the latter, you can replace the core without pulling the dash and total outlay doing it yourself will be under $200.
    Other alternative is to bypass the heater...just block the pipes. This is OK if you are north of Brisbane.
  1. coolant smell??
    By jonboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2010, 11:45 AM
  2. Coolant smell
    By 95Waghoon in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-10-2009, 07:12 PM
  3. Coolant smell
    By ringfeder3 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2008, 12:40 AM
  4. coolant smell??
    By clarkey3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 10:57 AM
  5. coolant smell
    By Mark in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2004, 12:48 PM
