Hi Guys,
this is what the car has on suspension done to it but it looks like the rear is sitting little bit higher than front, can this be fix and how?
Front: king springs with peddars gas sports ryder struts, i couldnt find out part# on king springs while looking at them with car jacked up
Rear: peddars springs part# 2641 and peddars comfort gas shocks..
also can anyone tell by eye by looking at pic to see if fronts have kings low/ super low or ultra lows in them?
[IMG][/IMG]
rear sitting a little bit higher? looks more like its under heavy braking,id say it has SL's in the front,just throw some SSL in the back and it should be about level
what does the ssl stand for? and would my standard shocks in there be good enough to use or will need changing?
super super low,probably best to fit new shocks but you could get away with it if your happy to have a bumpy ride etc
whats the part nimber on the rr comfort gas shocks? if its 8137 they are short stroke shocks already, if you cant find the part number are the 2641 in there tight or are they loose, if there tight they are short stroke.
