Results 1 to 15 of 15
Thread: Fitting oval indicators to a vr with square ones
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default Fitting oval indicators to a vr with square ones
    Hey I want to fit oval clear indicators to my vr withsquare ones...do I need to cut anything or will they go straight in
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    As said before straight in. Just be careful with the clips because they do get old with age (assuming you have second hand oval ones of course)
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Is there a way to fix them in so they don't get stolen ??
    I have wanted to get some for my VR, but have seen and read about them being easy to remove.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Besides super gluing them on (good luck changing bulbs) there really isn't much you can do.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Pretty sad if some one steals them. Surly not, they're like $15.
    Reaper
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Actually someone stole my clear indicators off my VS one night. I came out to see the wires dangling.
    Bastards.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    What a bunch of dero's. You can go to any wrecking yard in Australia pretty much and take them off the VT's for nothing.
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    The cretins are after the clear ones though.
    Perhaps use silicon to glue them in rather than glue? Will be easier to take them out if a globe needs replacing, just grab a razor blade and carefully slice through it.
    Then clear off all the silicon left and re-do it
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by Verynice View Post
    thats how i secured my vy ones i put on the old calais
    Chev badges are an instant fail
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    If its done neatly, then it shouldn't be too hard.
    Also when changing to clear lenses, don't forget to put in orange/amber bulbs.
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    I super glued mine, silicon is a nightmare on panels. With the super glue I used, its strong enough to give the impression it's somehow screwed on but obviously isn't. The glue on panel peels off like butter.
    VrWagz1's Avatar
    May 2008
    wollongong
    Rugular silicon rust's your car. Better off using somthng like quickgrip or any other contact adhesive. You can however get silicons minus the chemical that rusts your car to use aswell.
    Reaper
  15. #15
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    At under $15 a pop, I'd rather the scum take them instead of damaging the car because they're glued on.
    Try Sikaflex, will not rust the car (neutral cure) and you will NEVER get them off!!
  1. square testicles
    By Escape-The-Fate in forum Jokes/Humour
    Last Post: 01-05-2009, 03:25 PM
  2. Fitting side indicators to a VN
    By SAMO-87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-01-2008, 08:52 AM
  3. WOO...WOO...WOOO... i've got a green square
    By Hairy Eater in forum The Pub
    Last Post: 04-01-2007, 10:10 AM
  4. Fitting side indicators on a VN
    By Wingnut0021 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2006, 05:51 PM
  5. Oval indicators...
    By brentmc in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-12-2005, 01:58 PM
