Results 1 to 11 of 11
Thread: fuel problem
    brandon17 is offline BD-76-SR
    SV6 vz, vt clubby =P
    Jan 2010
    newcastle
    Angry fuel problem
    Hey, does anybody know why my vr would be chewing through fuel like alot.(full tank lasts about 90km , it has had a service this week. And still the same. Any help please?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    could be a heap of things..
    you need to tell us whats been changed, anything replaced recently, how do u drive.. have you had a search around to see what others have done with this same issue?
    could be as simple as ur handbrake is on or ur injectors are stuck open..
    whats your baseline, did it get worse or all of a sudden drop
    Vt Commodore Exec Series II
    Jul 2010
    sunshine coast
    can you smell fuel anywhere??, maybe check for leaks? 90kms a tank is pretty bad man
    .:FunkyMonk:.'s Avatar
    .:FunkyMonk:. is offline Just call me Steve
    VX manual mang machine
    Aug 2010
    RADelaide
    O2 sensors can run havoc with fuel consumption, have you replaced them?
    EDIT: Actually, hell almost anything can... but 90kms? That's just crazy....
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Would have to be fuel leaks, I get more than 90km with just $20 worth of fuel.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    do you have a brother? i reakon hes syphoning your tank!
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Fuel pressure regulator diaphram stuffed? Sucking fuel into manifold.
    Mmmmmm...........maybe not.
    If it was burning that amount of fuel you would have a cloud of black smoke following you where ever you went!
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    If its not blowing black smoke or revving its absolute nuts off, its either leaking or being stolen, Or you have a really small tank or the servo is rorting you big time. Try a different servo. !!
    What do the spark plugs look like ?
    Jul 2010
    sunshine coast
    try doing a fault code test on it as well mate, any info would help. i would definitely check for leaks though!
    Jan 2010
    newcastle
    Well it has been like It for a while. But Its just gdtting worse. I've replacdd the plugs. Yesturday, how do I do the fault code check thing?
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    1.Locate the diagnostic connector under the the steering column on the drivers side.
    2.Get a paper clip and bend it into a (U) Shape and bridge pins number 5 & 6 which are located on the top row counting from the left.
    3.Jump into the drivers seat and turn the key twice (so lights are up on the instrument cluster).
    4.If you bridged out the correct wires 'Check Engine Lamp' will be flashing.
    5.The flashes are divided into 2 groups with roughly a second between each. You can read the flashes as follows:
    The first series of flashes is tens, so for example lets say the first flash simply flashes once, this means the code is 10. After the pause (~1 second) a second series of flashes will appear, if this number is 2, the code it is spitting out is 12 which means everything is fine.
    6.Another example just so you're sure
    The first series of flashes you count is 4 meaning 40, the second series of flashes is 3. Adding the 40 and the 3 will give you a code of 43 which means the Knock sensor circuit is experiencing problems.
    7.Each code the computer picks up is repeated three times with ~3 second pause between, so its wise to sit there to make sure there isn't any problems it has picked up.
    8.Once you are finished turn off your ignition and remove the paper clip. It is important to note not to drive the car around while have wires are bridged as this will prevent new codes from being logged.
  1. Fuel / Fuel gauge problem
    By 2ndLook in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 06:50 PM
  2. fuel problem vr 5lt
    By craig vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2009, 04:44 PM
  3. fuel problem
    By reggie_c2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2008, 05:44 AM
  4. VN fuel problem
    By R Photon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2006, 01:16 AM
  5. VP V6 fuel problem
    By gmhvl6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2005, 10:19 PM
