Results 1 to 10 of 10
Thread: VS Wouldn't start
    Jul 2006
    Default VS Wouldn't start
    Couldn't get my VS started tonight and thought I was stranded. There was spark so I thought it was a fuel problem but I thought I'd try resetting the computer first out of desperation. Disconnected the battery and reconnected after a few minutes and it roared into life.
    Any thoughts? Do the ECU's just "die" or could it be something else?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could just be a "one off" and never happen again...if it happens again try do a codes check before you disconnect the battery. Is your battery over 3 years old?
    Jul 2006
    The battery is only a couple of days old, had a dodgy cheap one in there and it wasn't holding charge, hence the new one. It's done it once before and today it started idling rough.
    Jul 2006
    pulled off the injector plugs one by one and cylinder four isn't doing anything.
    Jul 2006
    Noticed I was losing coolant as well and what was left in the radiator is brown and sludgy.
    Cylinder four is only missing intermittently and when it does, this is when it heats up and starts losing coolant. Tried some Bars Stop Leak and it ran sweet and stayed cold all the way up the freeway then as soon as I stopped at the lights on the off ramp - up goes the temp gauge and running rough.
    Been searching through threads here for similar problems and what I've come up with is the intake manifold gasket, would this sound like a fair diagnosis?
    Jul 2006
    F***ing thing wouldn't start again today. Plenty of kick in the battery and there's spark that I can see.
    Has ANYONE got a suggestion? I'm meant to be at work again.. feel like I'm bashing my head against a wall here.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Jul 2006
    Quote Originally Posted by IBLOWN View Post
    I would do a compression test. Sounds like you may have a blown head gasket.
    The non starting issue was co-incidental. Turns out it's the key, have another key and it starts no worries.
    Seems odd that it would be a head gasket, shouldn't there be water in the oil? I've blown head gaskets on two different vehicles and ended up with chocolate milk on the dipstick both times. On this VS the oil is clean.
    It's odd, I managed to drive a fair distance and the motor stayed nice and cool, coming home last night I pulled off the freeway and up went the temp and cold air was blowing from the heater vent. When it started running rough, the only cylinder not firing was number 4.
    Sep 2005
    Jul 2006
    Ran some more Bars through it yesterday and have cylinder 4 back, it's running smooth again so hopefully that'll hold until I get time off to get to a mechanic.
  1. MY vt will not start HELP?
    By jaron88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-10-2010, 10:48 PM
  2. Wouldn't start when warm, now won't start at all
    By karwalski in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2010, 06:18 PM
  3. Help! - Car won't start
    By jayderichards in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-06-2006, 04:03 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
