Results 1 to 8 of 8
Thread: Raising the car...
    VR Acclaim V6
    Aug 2010
    Default Raising the car...
    Well i know by posting this i'm pretty sure most would disagree with doing so but instead suggest to lower it more, but i don't want a lowered ride.
    But how do i do that? Or is there any replacement springs which i could get to make the whole car higher?
    Thanks.
    MY04 VZ SS A4
    Feb 2007
    North Shore, Auckland, NZ
    Depending on the model you can get raised springs. You'll have to check with the spring manufacturers. King Springs (www.kingsprings.com.au) have the KHFR-19 which is a raised spring for the VR. Be aware that (unless your current springs are completely shagged) your car handling will suffer.
    If your VR is currently lowered (and you want to return the car to the original height) then you can get the standard height springs.
    If computers have no doors or fences, who needs Windows and Gates?
    Vy Ute, V6, Manual
    Mar 2009
    East gippsland Vic
    VR Acclaim V6
    Aug 2010
    I think they are stock springs and it's kinda sagged already i reckon. I sometimes hit the driveway curb with my exhaust tip.
    Here is a photo parked on a slightly slopped driveway. It slopes towards the garage.
    VR Acclaim V6
    Aug 2010
    Okie, i've read the catalogue and found that there is raised springs for the VR IRS.
    FRONT : KHFR-19
    REAR : KHRS-45
    has anyone used this springs before? Does the shock needs replacement with this springs?
    Thanks.
    VS acclaim
    Aug 2010
    Mooroolbark
    my mates vs has like some country suspension pack... its no joke... about 20cm higher than my vs on ultra lows
    VR Acclaim V6
    Aug 2010
    Quote Originally Posted by VS 666 View Post
    Yeah was thinking of something like that. I know my mates commodore has ultra lows in them as well i think, can't even get a bloody jack under it. and it's running 17's.
    VR Acclaim V6
    Aug 2010
    Okie i've just got a quote from a dealer near my place via Email. I would not need to change the shocks to a longer stroke ones unless the shocks are worn out. It's a direct replacement of for the springs set.
    All here is quoted in AUS Dollars. (Listed Price/Unit Price)
    Front 30mm raised springs - (175.00/148.75)
    Rear 30mm raised springs(IRS) - (196.00/166.60) [Live Axle's springs are cheaper compared to the IRS]
    Front Wheel Allignment - 50.00
    Suspension Labour - 230.00
    Now he did mentioned over the phone that if the cambers are out once raised 30mm's i would need to install in a IRS adjusting kit...
    GMH-R/IRS ADJUSTING KIT - (263.08/-)
    Suspension Labour - 300.00
    Rear Wheel Allignment -50.00
    Do you think that is about right? Cause i've got no idea and i've not gotten a reply from kingsprings yet as i'm thinking i might wanna buy directly from them. might get a better deal out of it and looking at the quotes, it's quite high isn't it?
    Oh yeah, i also just got myself slotted rotors for the front today with new brake pads. I guess i'd be installing them soon once my current pads wears out as the disc is kinda screwed already.
  1. Raising my baby
    By gothofic in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-08-2010, 10:12 PM
  2. Raising lowered VX
    By snoozeys in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2010, 07:05 PM
  3. Raising to Fe2
    By zvagon in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-03-2010, 04:26 PM
  4. Raising the compression
    By speed_freak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2009, 10:35 PM
  5. raising my car- want it to sit flat
    By lockmac in forum General
    Last Post: 12-10-2009, 08:03 PM
