Results 1 to 5 of 5
Thread: VS Stalls when steering wheel is turned.
    VS Calais
    Apr 2010
    Dandenong, VIC
    Default VS Stalls when steering wheel is turned.
    When my steering wheel is turned all the way to the left or the right my car stalls or shakes really badly.
    Any ideas?
    thanks.
    Quote Originally Posted by minux View Post
    I think Camrys only stay afloat because Indians seem to be sponsored by them...well in Vic anyway.
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Maybe the idle speed control motor is not responding to the load placed on the motor, causing the revs to drop too low.
    or
    If the steering wheel is juddering in your hand as you turn it, it may be the bush at the bottom of the steering column needs a lube (search this as it's a very common fault).
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    When you turn the wheel all the way to one side it places a lot of strain on your power steering pump and therefore your engine. Perhaps when the steering wheel is on its limit on one side or the other you are continuing to place pressure on the steering wheel, hence the shuddering and maybe the stalling. If your steering pump bearings are getting marginal it could also put more pressure on the engine causing a stall.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    As above either the steering pump is shagged or more likely an idle problem. First thing to check is the throttle body and clean out all the crud in the passages to the IAC valve which should help it idle faster
  1. [ACT] MOMO steering wheel & no brand steering wheel
    By calais24/7 in forum Parts And Other Items For Sale
    Last Post: 23-02-2010, 05:33 PM
  2. front left wheel makes a lowd bang when turned
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2009, 03:25 PM
  3. after market steering wheel made steering crap!
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 09:07 PM
  4. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
  5. Vn stalls when steering on full lock....
    By Sons1vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2005, 09:54 AM
