Results 1 to 5 of 5
Thread: Anyone had this problem??? Wierdest f---up of all time
    Vx Series II R8 Clubsport Build 295
    Apr 2009
    Perth, WA
    Unhappy Anyone had this problem??? Wierdest f---up of all time
    Ok so the other day i was driving to tafe, i exited the freeway and at the lights my car started to make a clanging sound (like it has a flat spot), i turned the corner hoping i could get to tafe and then sort out the problem, just as i turned into the tafe car park the power steering, brakes, alternator, etc all stopped working, apart from the motor itself.
    after stopping and having a look under the bonnet, i found the Fan Belt had shredded off. but the wierd thing was that the Power steering pully had come off too. not broken off but simple the bolts had undone and it fell off, (hence the clanging sound as it was coming loose). the nuts on the pully were fine so i got some more bolts and a new fan belt. the car is now fine.
    but im wondering if this has happened to anyone before and how the hell it happened?
    also i was wondering if this could have caused any faults with the power steering? it seems a bit heavier to turn than usual and it makes quite alot of groaning noises when it turns.
    stupid f**king commodores lolol
    LS1 Owners Club
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    no never heard of it, unless someone forgot to tighten them properly, groaning noises are either the bearings from the steering wheel shaft going through the firewall or there is air in the lines that the power steering fluid goes through. Is your ps tank full of oil? Checked for leaks?
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    The groaning is a separate issue. Spray some silicone spray into the rubber grommet in the firewall.
    The power steering pulley came off which caused the belt to throw off. Also when there's no belt there's no accessories, power steering, alternator or water pump. The motor will continue to run but don't, as it will quickly overheat.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Only heard of it one time before. Re the groaning noise when turning - spray the grommet in the firewall where the steering column goes thru - the seal there goes dry and groans....very common. Best access is from under the car.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    I'd bet whoever last changed your water pump didn't do up the power steering pulley bolts properly !!
  1. vz ss 1/4 time
    By oosty85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-11-2011, 05:20 PM
  2. Engine Misfires or doesn't wan't to start from time to time
    By redlion05 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-07-2010, 01:57 PM
  3. In need of a part time job (i work full time)
    By Niggadore in forum The Pub
    Last Post: 29-10-2009, 07:50 PM
  4. engine light on and stall time to time asap help
    By kevinwilly123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2009, 09:32 AM
  5. It's Time
    By Pretender in forum The Pub
    Last Post: 07-09-2006, 04:56 PM
