Results 1 to 5 of 5
Thread: help vs motor with vt auto ???
    vn s
    Nov 2009
    Default help vs motor with vt auto ???
    hey
    will a vt auto 7hdd fit onto a vs motor
    thanks
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    what did the vs have before? as in the original trans
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    what model car is it? it depends on what ecu you have as there are differences
    VR 1994 - 4HDD/V6 - 4HBD/V8 first electonically controlled auto.
    VR II 1995 - 5HDD/V6 - 5HBD/V8 extra solenoid fitted to provide softer "LOCK UP" torque converter clutch apply.
    VS 1996 - 6HDD/V6 - 6HBD/V8 the design of the previously added solenoid was changed and is not backwards compatible with the previous model.
    VS II 1997-7HDD/V6 - 7HBD/V8 basically the same as the 1996 unit except the thread size of the cooler pipe unions was enlarged.
    Thread Here
    gearbox confusion
    vn s
    Nov 2009
    VS 1996 - 6HDD the 7hdd bolts up but the cooler line wont
    what cooler lines do u use
    1995 vs ss commodore
    Jul 2011
    auckland
    ive just put a new 6hbd in my ss but need to know witch fitting is a feed line and witch is the return line is the top fitting on trans the feed and the bottem fitting on trans the return? some 1 help
  1. [VIC] f.s: vn-vp motor and auto
    By SNAFFLER in forum Parts And Other Items For Sale
    Last Post: 15-01-2009, 07:51 PM
  2. i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor
    By highmat_8686 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 09:32 AM
  3. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  4. VN V8 Motor - Auto
    By rian in forum V8 Development and Modification
    Last Post: 04-11-2006, 01:31 PM
  5. VS Auto starter motor
    By Easytarget in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-07-2005, 02:08 PM
