Results 1 to 6 of 6
Thread: VR SS starting problem
    VR Calais 5ltr
    Feb 2006
    Default VR SS starting problem
    Hey guys. Recently aquired a 94 VR SS. It was starting fine when i picked it up and all that day. Now when i go to start it, it cranks for ages before it starts to fire and even then i have to give it a few pumps of the accelerator and she splutters back to life. Once the car is started it drives and idles fine. This problem happens consistently, in the morning before work and in the afternoon coming home.
    Today i noticed also while cranking i could smell a strong fuel smell. I'll be checking the plugs tomorrow. It seems that it takes longer and longer to start each time i drive the car. Possibly fouling plugs? Maybe fuel reg problem or something..
    Any ideas are appreciated, thanks. Tim.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    maybe leaking injectors? if it isnt so bad after shutting it off briefly then i would suspect them
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VR Calais 5ltr
    Feb 2006
    Thanks mate ill have to look into that, and i think you are onto something because today when i started the car i watched the back end and i saw a few puffs of black smoke (fuel) coming out the exhaust for a second or two while starting. One started there is no black smoke and car operates normally.
    VR Calais 5ltr
    Feb 2006
    Im pretty sure its injectors because the car starts fine if started a short time after turning off, where as if left longer is very hard to start, lots of black smoke What happens with leaking injectors? Do i have to just replace them? Is it more likely to be more than one injector? How do i test if they are leaking? Pull them out and watch for drips?
    VS 5L M5 VS 6L M6
    Apr 2009
    i think u can get them ultrasonically cleaned but im not 100% sure if that will fix it. i'd assume that if 1 is gone the rest might not be far off. to the best of my knowledge thats how ya check them, lift the fuel rail+injectors, put some paper under the injectors so any leaks will show, check a few hours later
    Avoid cluey police
    1989 VN EXEC
    Jun 2009
    what was the out come of this , cause my vr is doing the same
  1. vs 304 starting problem(plz help)
    By TY318 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2010, 10:03 PM
  2. starting problem
    By djeyecon in forum V6 Development And Modification
    Last Post: 29-07-2008, 11:13 PM
  3. Vt Starting problem
    By bubz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2007, 10:22 PM
  4. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  5. starting problem
    By whatisnttakenalready in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2007, 10:29 AM
