Results 1 to 12 of 12
Thread: Vr codes 21 and 22 ?
    VR V6 UTE
    Mar 2010
    Default Vr codes 21 and 22 ?
    I was getting codes 21 and 22, so I replaced the TPS and the IAC but still the codes come up,
    is there something else that might need to be looked at?
    Cheers.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    was the codes cleared after the job was done?
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    VR V6 UTE
    Mar 2010
    Quote Originally Posted by moff_man View Post
    When I replaced the TPS I disconnected the battery, would that clear the codes?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    the bast way to be sure is to try starting it while the battery is disconnected. This drains residual power from the 'computer' and ensures the codes are cleared. Then reconnect the battery and check for codes before you start the car. If the codes are still there they have not been cleared and you need to try again.
    Are you getting any problems other than the codes ? like rough idle, or jerky throttle response ?
    VR V6 UTE
    Mar 2010
    Quote Originally Posted by greenacc View Post
    The idle is a little rough, but it has a big cam in it a 230@50, Ive had the memcal tuned, was an auto before, now is a 5sp manual, throttle response is ok.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    the big cam would explain the rough idle. Try clearing the codes again and see if they come back.
    VR V6 UTE
    Mar 2010
    Well, cleared the codes ok, but they came back again, the engine light comes on when it warms up, if that means anything?
    Cheers.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    So your ECU thinks you have a problem. Is your car still running OK ? When you replaced the TPS how did you do it ? did you align the slot with the end of the throttle shaft and turn the tps a bit to put some tension on the internal spring before tightening the 2 screws ? Does the idle get worse when you switch in the AC ?
    All I know about TPS is that if you play around with em too much you #&@% them, but the2 i've done in the past went in no probs. Did you reset the idle and all that after you did it ? if there is an idle reset procedure for the Buick?
    VR V6 UTE
    Mar 2010
    Yes the car runs ok, I just put the TPS on and had to turn it a little to put tension on it and did up the 2 screws, the AC isnt working as its out of gas, due to the motor rebuild.
    It does tend to die down in the revs when coming to a stop, but I thought that would be cos of the auto loom still in it, even though it has had the memcal re-tuned.
    Damn car
    Cheers.
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    TPS the exact same as the old one?
    I went to change mine in my VS and I got the black with grey body (VR) when it's supposed to be full black (VS). Then I think there is one more maybe?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    vr wagon
    Aug 2010
    vic
    i did mine the other day, make sure its tightened right up. i broke a screw and taped it into place to get to repco had them codes and engine light...... fixit and reset the ecu n they went away... check the wiring.... make sure you put all the hoses back in your throttle body... i forgot lol... to reset the idle turn car o,n hold at 1500 - 1800rpm and link pins 5 6 at the same time as you would do to check for codes. you should hear the car idle drop down and its reset... hope it helps...
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Err what are you on about CHA53R. To reset the IAC you rev the car out to 3k for about 30 seconds and back off the throttle at which point the revs should go to just above 1k and you will see it gradually stepping down to 500. Usually.
  1. Vin codes
    By Brett_jjj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2009, 10:44 AM
  2. vt codes
    By adamandtanya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-06-2009, 05:48 PM
  3. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  4. ECU Codes
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-07-2005, 01:11 AM
  5. codes 13, 46, 47, and 76 ?!
    By dob80z in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2005, 09:31 PM
