Hi Guys.
I am going to have a go at the inlet gasket on the VR.
Got the gaskets and Rubber gasket front and back ordered & torque wrench. Also the 2 plastic heater hose connectors on the cover as holden told me they brake most the time.
Besides that is there any tricked i should know about? looks pretty straight forward, when i clean the inlet cover, do i have to remove the injectors if i want to clean it? and if o do i need to replace the o rings on the injectors. Any tips would be great![]()
I did mine on my vs the other week not sure about the vr though, shouldn't be to much different, The fuel rail and injectors i left on the inlet manifold cover as i took it off and just cleaned off all traces of old sealant and cleaned up with some throttle body cleaner, its up to you if you want to do injectors.
you should undo and do up the inlet manifold bolts in a special order
will see if i can find it and post it up, if not im sure some one will be able to list it
no just do up the middles then go outwards
I Have the manual for it and the special order on tightening them up. Its like from middle outwards in a diagonal pattern. just wanted to see if theres any things that i should know that might happen.
Well it all went well. I made a how to on changing it, hope it will help some
Vr inlet gasket replacement
good on you for doing a how-to, its a common problem and will help alot of people im sure.
