Results 1 to 6 of 6
Thread: Statesman 5.0 wont start after doing heads
    Deneo's Avatar
    Deneo is offline Lock your Daughters up
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Default Statesman 5.0 wont start after doing heads
    Hey guys
    Recently did my head and inlet manifold gaskets, had the origonial intentions of doing heads and cam but decided to get another 4x4 aswell as my stato so just did all the gaskets.
    Got it all back together and went to start it but it wont fire, it's got Fuel and also has spark and i'm sure the timings right.
    It cranks over fine needs a new battery but been jumping it off my old girls fourby so plenty of juice there. It sounds like it wants to start, i had a few backfires when i started but nothing now.
    So i'm stumped i cracked the shits and left it for tomorrow, Anyone have any ideas ?
    Any help would be greatly appreciated,
    Deneo.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Have you checked that the distributor has number 1 cylinder in the correct position?
    Some times the lifters pump up and wont allow the valves to fully close. Try again in the morning as the lifters would have had a chance to bleed down a bit.
    I assume you have not removed the cam chain?
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    nope only touched the heads. ill check the timing when i get home, cheers.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    is there an earth strap on the heads on these? possibly if this is off it could cause an issue. but i guess the starters turning fine so i would assume the earth is fine.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Yeah everything seems fine starters turning perfectly so i'm stumped lol. I'll give it a once over tomorrow night because i have a killer headache atm and the stato will just make it worse lol
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Did you hook eveything back up, like tps, coolant temps sender, iac. I would have a close inspection that everything is plugged in properly again.
    Reaper
  1. statesman 5l wont start!! ecu maybe a problem??? need help asap!!!
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2010, 07:20 PM
  2. Vs 5LTR statesman WONT START
    By lippy88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2010, 08:45 AM
  3. Vs statesman wont start
    Last Post: 19-05-2010, 11:55 PM
  4. Help please vr statesman short out now wont start
    By H1GHROLLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2010, 06:33 PM
  5. VQ statesman Wont start
    By Meerkat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2008, 07:12 PM
