Results 1 to 8 of 8
Thread: Vr: Stumbles/stalls on takeoff?
    vr wagon
    Aug 2010
    vic
    Question Vr: Stumbles/stalls on takeoff?
    hi there, my vr wagon has recently started to stumble/stall on takeoff... it only seems to do it on a near or complete stop.. i go to take off and it drops out for a second before taking off. like it wants to stall but kicks back in again... i have checked for fault codes and coming up clean code 12..thought it might be a fuel blockage so did the filter and nothing, just replaced TPS and nothing again.. i reset the ECU and ran ok for about 5 mins then started again.. iv recently changed the spark plugs, oil switch, oil, fuel, air and oil filters, battery. had the alternator checked... bloody got me baffled... ANY THOUGHTS ON WHAT IT COULD BE?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try cleaning the throttle body and IAC (idle air control valve)...if they get glugged up it will cause this problem. Also closely check all vacuum lines around the TB.
    vr wagon
    Aug 2010
    vic
    checked all the lines and they seem fine, cleaned the throttle body when i changed the TPS but didnt think to clean the AIC.... do i just spray throttle body cleaner into it and wipe off or use metho or something?
    vr wagon
    Aug 2010
    vic
    ok cleaned the AIC valve, was dirty as..... cleaned all of the holes inside the throttle body.... and while i was there checked the crank angle sensor and the plug on that was pretty dirty too... cleaned that and one of the metal slots on the plug lookes pretty crap so i tryd scratching on it to bare metal. cleaned that to the best as i can.. dryed off with paper towl and let sit for 20 mins then put a hair dryer on it all for about 5 mins took it for a drive, thought mad its gone... soon as the car warmed up the bloody thing starts again.... any suggestions?
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Coil Packs, DFI Module, Dirty or Clogged Fuel Filter.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    vr wagon
    Aug 2010
    vic
    did the fuel filter last week, going to do the ignition leads in a couple of days... will check the coils while im there.....
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    vr wagon
    Aug 2010
    vic
    it was fine till i did the service, but iv only had it 2 months too. the only thing i didnt fully replace was the leads, i found 2 faulty leads and replaced them with leads off a vn, but dont think it was that but am replacing them anyway this week just in case..i put a amp and head unit in and started around that time... i unpluged them and didnt change.. just plucking at straws now...
  1. Clunk noise after startup/takeoff
    By dozenmatta in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-10-2009, 01:42 AM
  2. Loud noise on takeoff
    By rowdybloke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 11:11 PM
  3. Stumbles on take off...It can't make up it's mind!
    By Mordred in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2007, 06:38 PM
  4. Scratchy noise on takeoff under load
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-10-2005, 09:50 AM
  5. Shudder on takeoff?
    By DamoVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-01-2005, 04:05 PM
