Results 1 to 7 of 7
Thread: Rear main seal , sump gasket
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    Red face Rear main seal , sump gasket
    Hi All
    Just wondering if any body has changed sump gasket-rear main seal on
    3.8 V6 series 3 ute , and what is the best way to do the job with out removing
    the engine ? Thanks.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Remove the gearbox and the crossmember under the motor.
    vs calais
    Dec 2008
    Quote Originally Posted by RX25SE View Post
    sorry abit confused with this... how can you remove the crossmember with the engine still in the car? the engine bolts up to the crossmember if im correct
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    With the use of an engine support bar.
    It runs across the engine bay and sits on the edge of the inner guard. It has a moveble adjusting hook in the middle that supports the motor.
    I use this one but there are others.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by admir87 View Post
    You need to support the motor across the strut tops with an engine support, so yes, the motor will be hanging from a chain with no support underneath. Its the best way to do it.
    Aug 2008
    NSW South Coast
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    Cheers for that guys sounds like a prick of a job at the best of times .
  1. can you remove the Rear main seal buy removing the sump
    By hrtmad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2011, 01:42 AM
  2. 304 Rear main seal on 5.0 V8
    By Warranty Void in forum V8 Development and Modification
    Last Post: 10-05-2010, 02:23 PM
  3. VN Power Steering, sump and rear main seal
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2009, 12:20 AM
  4. Rear main seal Gen 3
    By Flano in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2009, 02:42 PM
  5. rear main seal, left engine mount,valley cover gasket,minor service $900is that good
    By eagle13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-12-2005, 10:31 PM
