Results 1 to 4 of 4
Thread: Need help asap for my vs :s
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    Default Need help asap for my vs :s
    ok the other day my heater tap went on my holden vs v6 and b4 that everything was fine with the motor so i replaced the heater tap with a new one and when u start it its fine but when u try and rev it or when its in gear and try and move it it stalls and i have noticed that there is alot of water coming out of the exhaust and it is using alot of water and white crap on the oil lid but there is no water in the oil and no oil in the water im so confused need help thanks Darcy
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    White crap under the oil crap means there is water in the oil.
    How long did you drive it with the buggered heater tap?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    if there is a milky substance in the oil, that more then likely indicates a Blown Head Gasket. And spitting water out of the exhaust is another symptom should not related to a heater tap problem. I would have that checked first, you can buy that stuff that u put in the radiator and it changes yellow or green I think if exhaust gases are found in the radiator.
    Mar 2010
    Cockatoo Vic
    Quote Originally Posted by Andrew426 View Post
    i drove it for about 10k
  1. Need help asap!
    By richardbignutsonstato in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2009, 02:22 PM
  2. help asap
    By KPB00F in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2008, 06:46 PM
  3. VR 93 needs help!!! ASAP
    By maco_butterfly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2008, 02:42 PM
  4. need help asap
    By bradvt98 in forum Car Audio
    Last Post: 16-12-2006, 06:03 PM
  5. please help ASAP
    By tas_devil in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-12-2006, 11:32 AM
