hi there..
My car has code error 63 (Code 63 - LH Oxygen Sensor (O2) - No Signal )
not sure where to go to from here... Asked a couple of people and got completely different answers.
Vs 1997
any help would be appreciated
Try clearing the error codes by resetting the ECU, this is done by disconnecting the battery for a minute or two,then go for a drive, and then see if the error codes return. If they do, check the wiring and connectors to the sensors.... look for any broken wires etc.. if everything looks fine then replace the sensor itself.
