Results 1 to 7 of 7
Thread: Crankshaft sensor!!
    commodore VR
    Aug 2010
    brisbane
    Question Crankshaft sensor!!
    Heya Id appreciate feedback about my VR 93 v6 that decides not to start if turned off for less than ten minutes. It has been suggested its the crankshaft sensor?? It will actually start but then dies immediately..as I say if sitting for a while then it usually starts no problem. Should I get a diagnostic test to find out for sure or is there a cheaper way?
    Cheers for the help and feedback
    vr wagon
    Aug 2010
    vic
    do what im going to try tomorrow.. when it starts playing up, pour cold water on it and see how it goes... if it starts straight away and no problems till it warms back up... needs replacing... hope it helps...
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Check you error codes as well. There's a how to on here. If anything comes up about the CAS being faulty I suggest you replace it and the balancer if it looks worn. Although going by your brief description it certainly sounds likely to be the cause of your issues.
    commodore VR
    Aug 2010
    brisbane
    Ok thanks! You wouldnt happen to know if its an easy enough DIY jobby to ya?
    commodore VR
    Aug 2010
    brisbane
    ok will give that a go, its started taking more than an hour before it will start, but will give this ago today, and let ya know?
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Buick and ecotec crank angle sensors have a history of playing up when hot.
    A trick that has worked sometimes is to pour some cold water onto the CAS when it won't start when hot.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    commodore VR
    Aug 2010
    brisbane
    Well bugger me as posted in my other thread, It wont start at all now just keeps winding. So does this mean its died cos of the CAS?? What now? One suggested coil, anyone know how to check if it is? Cheers
  1. [VIC] WTB:vr v6 crankshaft
    By slprwgn in forum Swap / Wanted to Buy / Trade
    Last Post: 29-03-2010, 12:08 PM
  2. Error code 41, Crankshaft Sensor
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 06:23 PM
  3. crankshaft sensor
    By im blonde? in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2007, 01:52 AM
  4. Now that's a Crankshaft!
    By IanG in forum The Pub
    Last Post: 06-05-2006, 10:50 PM
  5. Need Vs Vt Crankshaft
    By ADZ124 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2006, 09:26 PM
