Results 1 to 10 of 10
Thread: Crankshaft Sensor???
    commodore VR
    Aug 2010
    brisbane
    Exclamation Crankshaft Sensor???
    Hey!
    My 93 VR has recently stopped starting when sitting for less than around 10-20 minutes. If you try and start it, it will start then immediately die... Have also noticed a slight stall from time to time when going from R to D...someone suggested the crank sensor. What do you think? If so, tell me all I need to know about it!! Aslo is it worth taking it to for a diagnostic check???
    BTW: all leads and plugs are fine, also wondering if anything to so with the fuel line somewhere..has a new fuel pump also.
    THANKS!!!
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    commodore VR
    Aug 2010
    brisbane
    VL Commodore
    Dec 2008
    commodore VR
    Aug 2010
    brisbane
    yeh was told if it were the coils it would have stuffed out completely...oh joy!
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    To quickly check Crankshaft Sensor. When the engine stops, pour about a cup of cold water over the sensor. If that permits engine to be restarted then there's your problem. Worked for me.
    1996 3.8L VS Commodore
    Aug 2010
    Watanobbi
    Quote Originally Posted by Ezybrezy View Post
    so not true, i got a mate that replaced his ECU, memcal, harmonic balancer and CAS all because of the problem it looks like u are having except in a vs and it still ran like a sick dog on a rainy day, it turned out to just be the metal plate that the coil packs sit on, dont know why or how it buggers so much up but it does, its worth a try...
    sorry forgot to mention he also thought he blew first gear up all because of that one thing it was running that sick...
    HX Kingswood Ute (Project)
    VN Berlina (Now a Donor)
    "91 Subaru Liberty (Blown Motor Ex-Daily)
    VS Commodore (Daily)
    commodore VR
    Aug 2010
    brisbane
    arrghh now the friggen thing isnt going at all! So does this mean its shat itself because of the sensor?? I didnt even get to try the water thing bugger it....Nowwwww what? S.O.S
    So maybe it is the coils! How will i know for sure??
    VS II Ute V6 1996
    Jan 2009
    Lake Macquarie NSW
    Have you checked the error codes yet? Check out this 'how to'
    Checking error codes VR/VS (Revised)
    commodore VR
    Aug 2010
    brisbane
    hey thanks!
  1. Crankshaft sensor!!
    By Ezybrezy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2010, 03:11 PM
  2. Error code 41, Crankshaft Sensor
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 06:23 PM
  3. crankshaft sensor
    By im blonde? in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2007, 01:52 AM
  4. Now that's a Crankshaft!
    By IanG in forum The Pub
    Last Post: 06-05-2006, 10:50 PM
  5. Need Vs Vt Crankshaft
    By ADZ124 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2006, 09:26 PM
