Results 1 to 5 of 5
Thread: VS Calais lvl 3 Dash resetting
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    Default VS Calais lvl 3 Dash resetting
    Hi all,
    I was just wondering if anyone can tell me how to put a level 3 dash back to how it should be.
    Currently when I use the trip meter the fuel used is about 10lt less than what is shown.
    The car has a BT1 PCM & it was formerly a S/Charged V6. It is Now a 5lt.
    This is the way I bought the car.
    The car runs Great, I'd just like the reading on the dash to be accurate.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The factory settings are 625 distance and 625 fuel flow. You press and hold the reset button for 3 secs. then + or - to get it back to factory settings.
    and 3 Dangerous non ABS VN's
    Mar 2010
    Around WA
    thanks for that 88GreenVN.
    by holding the set button for the trip computer for 3sec, that will get me into the settings?
    I'm not sure as you've got to hold it down for 2 seconds to reset a screen, (i.e Trip or overspeed alert).
    And which screen does it need to be in to access it?
    Do I need to hold the button as I turn on the ignition?
    Thanks for any help you can give & thanks again for the advice so far. :-)
    88GreenVN's Avatar
    Jun 2006
    All 3 modes need to be set 1 at a time. Distance is on the ODO (RHS) screen, fuel flow is in the middle as is the fuel remaining.
    While the ignision is on press and hold the reset button in al 3 modes and you will see which one is what. If you have a full tank fuel remaining should be set to you tank size or just under.
    Mar 2010
    Around WA
    Thanks for that, I'll have to give it a try when I get home tomorow.
  1. VK Calais digital dash to analog dash
    By mattw in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2008, 08:16 PM
  2. vp calais dash loom into vn calais
    By calais_8 in forum Electrical Wiring / Questions
    Last Post: 17-07-2008, 12:57 AM
  3. vp how to change dash to calais dash
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2006, 07:35 PM
  4. resetting..
    By Z()LTAN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2005, 12:46 PM
  5. Resetting VT Calais Odometer
    By Brett in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-10-2004, 09:15 PM
