i have a vibration in my vr s2 for those who didn't know, does it in any gear P R N D etc about just off idle to about 1500 rpm gets worse as the engine has been driving for a while
i have done: compression test, 200 psi all round (about 1300 kpa) plugs looked like good 5000km old plugs
replaced the torque converter to a known good one
resealed the sump and there was no signs in the sump of damage ie metal shavings etc.
known good balancer
than the obvious plugs leads
inlet manifold gaskets
just after ideas where to look next. if i have too ill spend the day at work on it.
Originally Posted by Adam Savage (mythbusters)
is it V6 or 5.0lt?
I had the same in my wifes VR SerII 5.0lt. I replaced the Balancer with a brand new one & it was fine.
The vibration was occuring @ 1700rpm aprox.
We started with leads & coil but managed to track it down to the Harmonic balancer.
the balancer may still look good however the balancer may have slipped round on the rubber ring or lost a weight.
just a thought.
however with the V6 I'm not to sure if they have a balance shaft or not.
v6 and it has a shaft
Engine mounts sagged and resting on crossmember?
thinking check engine mounts too
Umm actually I had the same thing when I had my berlina, is it constant? if so, take a look at your engine mounts, mine did it for ages to find out that they were so buggered.
engine mounts look good better than some others ive seen
that's ####ed man. All good signs and it still wants to #### up. 200 psi all round is godly =D
Partial missfire?
