Results 1 to 7 of 7
Thread: How much transmission fluid?
    96 VS Acclaim
    Mar 2010
    Default How much transmission fluid?
    Hey folks, I did my transmission filter today and topped it back up with some tranny fluid.
    I thought it would take a lot so I put around 2L in there, but the dipstick is showing that its WAY over filled...
    Anyone know how much tranny fluid a VS can take from empty?
    cheers.
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    start up your engine then re- try should take 3 - 4 ltrs
    Making and running DUAL CHIPPED ECU SINCE 2010
    96 VS Acclaim
    Mar 2010
    My battery is dead, is there any problem with leaving the 2L in there for a few weeks?
    cheers for the help! phew
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Quote Originally Posted by deXtrous View Post
    How are you checking the level then, if yor battery is dead?
    Car needs to running, hot and idling in park or neutral before you check the level
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Service manual says to add approx 4.8 litres following a fluid change and filter replacement in a V6. You have a long way to go.
    vr v6 commodore
    Sep 2010
    gatton
    im unsure of how much oil an auto trany takes but, what affects oil levels in a auto is how much oil is in the the torque converter
  1. Will a car run without transmission fluid?
    By deXtrous in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2010, 03:08 AM
  2. how to top up transmission fluid
    By nielsonp in forum General
    Last Post: 03-02-2010, 09:13 PM
  3. Transmission Fluid
    By Deutscher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2009, 03:04 PM
  4. Which transmission fluid
    By jonathanvb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2007, 06:50 PM
  5. Transmission Fluid
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2005, 01:03 PM
