Results 1 to 9 of 9
Thread: Taking VS Key apart
    VR
    Sep 2010
    Hunter
    Default Taking VS Key apart
    Yes old story but trying to get key apart to replace rubber buttons, please dont answer post if your reply will be no you need a new key because it isnt true and they can survive more than two hours without a battery and dont need reprograming.... I just want to know what glue they used to seal the buggers as I want to take it apart without damaging the case
    VS Executive 3.8
    Feb 2010
    Hey mate I just swapped my buttons over yesterday! Start by removing the screws and key which will make things a lot easier, then you should be able to spread that end slightly and slowly work your way around until you almost reach the end attached to your key rings. If your lucky the glue will "crack" and the key will pop open, it took quite a bit of force to open mine so be careful. You may have to place a couple drops of superglue on the two inner sides of your key too otherwise it will just fall apart again.
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    you dont have to "break" open the key at all,, use a small knife and cut the old buttons out then the new ones just push in,,
    Signature Goes Here
    VS Executive 3.8
    Feb 2010
    This is true, and probably a good idea. Although it's a lot neater if you can do it by opening your key.
    Nimbus 2000
    Sep 2008
    Hogwarts
    If done properly and carefully it will look close to factory where as trying to pry open the key you could scratch it,, even the instructions that come with the buttons say to cut the old buttons out. (il have to double check that but almost certain)
    Signature Goes Here
    1999 vs ute series 3
    Oct 2009
    just put new buttons in, got half way threw ripping the key apart and found out they just pop staright in :/
    Quote Originally Posted by Jonnii View Post
    yeah well it is a ute its not supposed to be about comfort
    http://forums.justcommodores.com.au/...rst-car-d.html <<< My 5sp vs ute
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Where do you buy the new buttons? Holden I take it, and how much please?
    BANNED
    Feb 2010
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    K cheers......
  1. taking out the spool :(
    By dumpedvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2010, 10:05 PM
  2. Taking gears out IRS.
    By LOWPSI in forum General
    Last Post: 20-06-2008, 05:42 PM
  3. car bogs down when taking off
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2008, 04:24 AM
  4. Taking things off
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2008, 06:14 AM
  5. When taking out my engine
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2008, 09:30 AM
Tags for this Thread
